Thermostat issues, Thermostat cable broke |
jrcui |
Jul 23 2005, 11:06 PM
Vinny Group: Members Posts: 80 Joined: 5-November 04 From: beaverton, or Member No.: 3,062 |
Since this is my first teener, I've been learning a lot and replacing a lot. I've noticed my car ran a little hot almost hitting the red on the temp gauge but she ran fine.
Yesterday, I was cleaning away a bunch of grime from under the car and noticed the thermostat cable was snapped. How hard is it to replace the cable and how much damage might I have caused driving around with the thermostat not working properly? Anyone in the Portland, OR area willing to take on an apprentice to pass on the 914 knowledge? Willing to spring for beer. Aloha, Vince (IMG:http://www.914world.com/bbs2/html/emoticons/beerchug.gif) |
Rand |
Jul 23 2005, 11:24 PM
The broken thermostat cable won't cause overheating. Assuming the spring is good, the default position is full-cooling. So it may take a little longer to warm up, but won't inhibit cooling.
If your temp is running high, it's probably something else. If the car is new to you, start with the basics.... a good tune up first. Mine was running a little on the warm side, and after replacing points and setting dwell & timing, temps went back to normal. (IMG:http://www.914world.com/bbs2/html/emoticons/wacko.gif) |
jrcui |
Jul 24 2005, 09:17 PM
Thanks! One of the first things I did was replace the points, rotor, plugs, and had an oil change done.
Vince |
Lo-Fi Version | Time is now: 29th April 2024 - 03:32 PM |
