Engine cuts out, Help |
ted |
Jul 24 2005, 09:55 AM
Newbie Group: Members Posts: 1 Joined: 19-July 05 From: Westerville, OH Member No.: 4,433 |
My '74 1.8 starts and runs fine for a while. Then it begins to buck or cut out. At firsy it is very intermittant, but becomes more frequent as it is driven until it becomes a neck-snapping experience. The car is all original and fuel injected. I am not a mechanic, so responses must be basic. Non of the local mechanics that have looked at the car seem to have a clue. I am in central Ohio - suggestions for knowlegeable repair shops would be welcome. (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif) HELP
Gary# |
Jul 24 2005, 10:32 AM
Member Group: Members Posts: 217 Joined: 15-May 05 From: Buena Park, Ca. Member No.: 4,078 |
Check all of the wires that attach to the coil.
Clean all the terminals. Make certain that the wire's are tight and not arcing. If U can, watch it idle in the dark. Look for arcing. All of your wires are 30+ years old. If there anything like mine, the insulation has become brittle and cracked. Replace them. Good Luck (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) |
Joe Bob |
Jul 24 2005, 10:50 AM
Doan fergit the fuel filter.....
As to ignition...once had the coil wire come loose.....thing arced arcross two inches and it STILL ran until the wire burned up.... (IMG:http://www.914world.com/bbs2/html/emoticons/cool_shades.gif) |
qa1142 |
Jul 24 2005, 02:53 PM
Whiplash Group: Members Posts: 1,514 Joined: 1-June 04 From: Lake Zurich, Illinois Member No.: 2,140 |
Just had this on my 1.8L
Change the head temp sender. Mine even tested good, but that fixed it ~$30 |
bd1308 |
Jul 24 2005, 02:57 PM
how far is westerville from dayton?
road trip? |
redshift |
Jul 24 2005, 02:59 PM
Also. look at the wire from the fuseblock, to the coil, related to the safety belt interlock.. cut that wire.
(IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) M |
bd1308 |
Jul 24 2005, 03:01 PM
batmiles, grab me a pic of that, can you? |
Lo-Fi Version | Time is now: 16th May 2024 - 04:59 AM |
