Help - Djet running way too rich |
Halfnelson |
Jul 23 2021, 06:51 AM
Newbie Group: Members Posts: 46 Joined: 31-July 17 From: Cornwall Member No.: 21,303 Region Association: England |
Help - my new to me 1973 1.7 Djet came running really sweet, but almost immediately developed the 'hunting tick-over' of lean running / air leak. We replaced all the vacuum pipes, found one of the inlet gaskets had a very slight leak. Seems somewhere along the line things have been tweaked to compensate for the leaks so that now they're cured, the car is running super rich. Having had a L-jet for years the Djet is new to me so any advice on where to start first would be much appreciated. Thanks Chris
Halfnelson |
Aug 11 2021, 08:45 AM
Thanks for everyone's feedback on this. I've finally got an update on things. After a couple of false dawns I'm hoping we've nailed the issue. Total work included:
Checking MPS - OK New fuel lines, filter and fuel pump Sorting the ignition as the spark was weak - so new coil etc Going through all wiring and fuses New CHT sender New plugs for injectors My guess is multiple small faults adding up to a lot of head scratching when we thought the problem was solved... only for it not to be. Done a few local trips including a car show at the weekend. Fingers crossed now for a longer test drive. |
Lo-Fi Version | Time is now: 19th May 2024 - 05:46 AM |
