Help - Djet running way too rich |
Halfnelson |
Jul 23 2021, 06:51 AM
Newbie Group: Members Posts: 46 Joined: 31-July 17 From: Cornwall Member No.: 21,303 Region Association: England |
Help - my new to me 1973 1.7 Djet came running really sweet, but almost immediately developed the 'hunting tick-over' of lean running / air leak. We replaced all the vacuum pipes, found one of the inlet gaskets had a very slight leak. Seems somewhere along the line things have been tweaked to compensate for the leaks so that now they're cured, the car is running super rich. Having had a L-jet for years the Djet is new to me so any advice on where to start first would be much appreciated. Thanks Chris
rjames |
Jul 24 2021, 10:19 AM
I'm made of metal Group: Members Posts: 3,933 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
Calibrating the MPS correctly requires being able to know what the AFR is at idle, part load and WOT.
It could be said that fully dialing it in requires an inductance meter, but it isn’t necessary to get the car running well. Fix/replace faulty FI components, don’t just bypass them. They are there for a reason. For example, removing the decel valve will shorten the life of the MPS diaphragm. |
mgphoto |
Sep 6 2022, 01:00 PM
"If there is a mistake it will find me" Group: Members Posts: 1,339 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California |
Calibrating the MPS correctly requires being able to know what the AFR is at idle, part load and WOT. It could be said that fully dialing it in requires an inductance meter, but it isn’t necessary to get the car running well. Fix/replace faulty FI components, don’t just bypass them. They are there for a reason. For example, removing the decel valve will shorten the life of the MPS diaphragm. No it won’t, going on ten years and 40k miles, deaccl valve is a stop gap pollution device pretty much ruins engine braking. |
Lo-Fi Version | Time is now: 19th May 2024 - 03:23 AM |
