Help - Djet running way too rich |
Halfnelson |
Jul 23 2021, 06:51 AM
Newbie Group: Members Posts: 46 Joined: 31-July 17 From: Cornwall Member No.: 21,303 Region Association: England |
Help - my new to me 1973 1.7 Djet came running really sweet, but almost immediately developed the 'hunting tick-over' of lean running / air leak. We replaced all the vacuum pipes, found one of the inlet gaskets had a very slight leak. Seems somewhere along the line things have been tweaked to compensate for the leaks so that now they're cured, the car is running super rich. Having had a L-jet for years the Djet is new to me so any advice on where to start first would be much appreciated. Thanks Chris
emerygt350 |
Sep 6 2022, 01:01 PM
Advanced Member Group: Members Posts: 2,098 Joined: 20-July 21 From: Upstate, NY Member No.: 25,740 Region Association: North East States |
Yeah, check that cold start valve.
Any chance you can borrow another ECU? (another quick and easy check if it is available). I have to suspect soemthing catastrophic with something like the csv. Even max rich by the ECU wouldn't cause what you are experiencing. I seriously doubt your brand new injectors are stuck open. as stated above... it's the only other thing bringing fuel. You could block the csv fuel line (super easy) and give it a go. Not even sure the trigger points or malfunctioning 123dizzy could cause this either. |
Halfnelson |
Sep 6 2022, 01:07 PM
Yeah, check that cold start valve. Any chance you can borrow another ECU? (another quick and easy check if it is available). I have to suspect soemthing catastrophic with something like the csv. Even max rich by the ECU wouldn't cause what you are experiencing. I seriously doubt your brand new injectors are stuck open. as stated above... it's the only other thing bringing fuel. You could block the csv fuel line (super easy) and give it a go. Not even sure the trigger points or malfunctioning 123dizzy could cause this either. The CSV should have been done - but I'll double check as that makes sense. Also, will try and borrow an ECU. |
Lo-Fi Version | Time is now: 19th May 2024 - 04:58 AM |
