Help - Djet running way too rich |
Halfnelson |
Jul 23 2021, 06:51 AM
Newbie Group: Members Posts: 46 Joined: 31-July 17 From: Cornwall Member No.: 21,303 Region Association: England |
Help - my new to me 1973 1.7 Djet came running really sweet, but almost immediately developed the 'hunting tick-over' of lean running / air leak. We replaced all the vacuum pipes, found one of the inlet gaskets had a very slight leak. Seems somewhere along the line things have been tweaked to compensate for the leaks so that now they're cured, the car is running super rich. Having had a L-jet for years the Djet is new to me so any advice on where to start first would be much appreciated. Thanks Chris
mgphoto |
Sep 6 2022, 01:10 PM
"If there is a mistake it will find me" Group: Members Posts: 1,339 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California |
Pull one side of the fuel rail off while the engine is running, note the amount of spray, at idle it should be minimal, if the injectors are just open the ECU is at fault.
emerygt350 |
Sep 6 2022, 01:38 PM
Advanced Member Group: Members Posts: 2,098 Joined: 20-July 21 From: Upstate, NY Member No.: 25,740 Region Association: North East States |
Pull one side of the fuel rail off while the engine is running, note the amount of spray, at idle it should be minimal, if the injectors are just open the ECU is at fault. You mean the injectors right? Make sure you put them In coffee cans too. Double check that csv first since it is easy. Have you checked your fuel pressure recently? On the rails? |
Lo-Fi Version | Time is now: 19th May 2024 - 05:26 AM |
