Help - Djet running way too rich |
Halfnelson |
Jul 23 2021, 06:51 AM
Newbie Group: Members Posts: 46 Joined: 31-July 17 From: Cornwall Member No.: 21,303 Region Association: England |
Help - my new to me 1973 1.7 Djet came running really sweet, but almost immediately developed the 'hunting tick-over' of lean running / air leak. We replaced all the vacuum pipes, found one of the inlet gaskets had a very slight leak. Seems somewhere along the line things have been tweaked to compensate for the leaks so that now they're cured, the car is running super rich. Having had a L-jet for years the Djet is new to me so any advice on where to start first would be much appreciated. Thanks Chris
JeffBowlsby |
Sep 6 2022, 01:53 PM
914 Wiring Harnesses Group: Members Posts: 8,520 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Two other things to check:
TS2 - cyl head temp sensor. It can fail to dump enough fuel not allowing it to start, perhaps yours is intermittently failing. MPS - check its ability to hold vacuum. Does it hold up to 18 inHG steady, or is there a vacuum leak? When the diaphragm fractures it fails rich. No vacuum or a rapid vacuum loss will be very rich. |
Lo-Fi Version | Time is now: 28th May 2024 - 05:27 AM |
