Master cylinder installation, First time |
EJP914 |
Jul 24 2021, 03:03 PM
Member Group: Members Posts: 260 Joined: 14-June 03 From: Monroeville, PA Member No.: 821 |
Got the new MC from PMB. Have a bunch of questions on installing. Hopefully you guys can help me.
1. Do you remove the 2 rubber grommets from the new MC and then put them on the flared lines from the reservoir OR do you push the flared lines into the grommets while they are in the MC? 2. Got 2 aluminum washers. Where do they go? In the MC under the grommets? 3. How far down can I pull the plastic lines from the reservoir once disconnected from the reservoir? They look to pass through a rubber boot on the sheet metal. The more space the better under the car for reconnecting??? 4. Is there some tool you use to push the grommets back in or is it a wiggle and twist? Would it help if they were lightly coated with brake fluid to get them back in? 5. Read somewhere someone removed their gas tank to do this job. IS that really necessary? 6. If there is a video somewhere on how to do this, please refer me. Sorry for all the questions. This is my 5th 914 but never had to do this job before. Thanks for the help. EJP914 |
EJP914 |
Jul 27 2021, 01:18 PM
Got my lines mixed up. Does the rear most line from the reservoir connect to the rear most grommet on the MC? Don't want to cross them up. Can someone PLEASE confirm. Thanks
Lo-Fi Version | Time is now: 18th May 2024 - 11:29 AM |
