Dropping the engine, Can I do it with the HE still attached? |
913B |
Jul 27 2021, 12:58 PM
Senior Member Group: Members Posts: 847 Joined: 25-April 05 From: South Bay/SoCal Member No.: 3,983 Region Association: None |
So I want to drop the engine to install a CHT modification under the spark plug hole.
I also need to install a crank sensor. I am a bit hesitant because I don't want to risk pulling an exhaust stud out like last time. I suppose it's a good reason to address that bolt again? I feel it is loose or something because the exhaust is kind of loud in my opinion but arent they are loud, to begin with? Well if it is loose what is the proper way to fix it? Take the block to a machinist and have them fix it? I feel my previous repair was not good enough. I drilled it out, tapped it, then installed some time cert and the stud. I just don't want to open a bigger can of worms. Whatcha all think? Thanks guys! |
Lo-Fi Version | Time is now: 25th May 2024 - 12:39 AM |
