UROpartsman |
Member ![]() ![]() Group: Members Posts: 295 Joined: 22-October 15 From: Simi Valley, CA Member No.: 19,288 Region Association: None ![]() ![]() |
High-quality URO Parts Pedal Bearing Tube 901 423 035 00 for 1965-1977 911, 1965-1969 912, and 914 cars has just been released! (Does not fit cars with power brakes.) The brake pedal pivots on the OD of this tube, and the clutch pedal pivots in the ID. The phosphate surface finish helps resist corrosion, and has an original appearance. These Pedal Bearing Tubes retail for around $90 and will be available from Porsche specialists such as:
Sierra Madre Collection in Southern California Clutch Cable Tube 901 423 035 00, 1970-76 914 https://sierramadrecollection.com/Clutch-Ca...-76-p23634.html Auto Atlanta in Marietta, GA Pedal Bearing Tube 901 423 035 00 http://www.autoatlanta.com/Porsche-Pedal-B...0142303500.html If you have any questions about URO Pedal Bearing Tube 90142303500, feel free to contact us at 800-290-5555 or "sales @ uroparts . com" (remove spaces). Mating bushings are also available from URO as a part of Pedal Bushing Kit 911 423 300 KIT (which includes inner bushing 911 423 341 01 and outer bushing 911 423 542 00). |
Lo-Fi Version | Time is now: 11th July 2025 - 10:47 AM |
