What HP level requires transmission upgrades?, I have 200 HP to the wheels, what do I need? |
FourBlades |
Aug 6 2021, 09:42 AM
From Wreck to Rockin Group: Members Posts: 2,054 Joined: 3-December 07 From: Brevard, FL Member No.: 8,414 Region Association: South East States |
I realize it is probably torque that kills a transmission, but I don't know the torque output of my engine.
I am building a 901 transmission for my IMSA 914 and wonder what upgrades it will need. I have some possible upgrades I could do now. First, I have a set of 930 stub axles, CVs and the corresponding sway-away axles for a 914. They are stronger and the CVs are available for $80 from pelican. Downside is I have to destroy the existing rear bearings in my axles to use them, which were rebuilt by PMB. If I have 200 HP to the wheels are the 930 CVs a necessary or worthwhile upgrade? Second, should I upgrade to the billet intermediate plate at this HP level? If I do, will I have to reset the pinion depth? That is something I can't do myself and would need to find a shop here in Florida that can do it. I know this is overkill for a typical 914, but with 12 inch rear tires and a 2.5L six, is this when the upgrade is worth while? I am not adverse to starting with the 914 axles and upgrading down the road. Pulling the engine and transmission is not that time consuming. I would hate to break the smaller axles or CVs the first time at the track though. I have a stock gearset and know there are probably better gear choices for Sebring, Daytona, etc. No idea where to start with those. I will be running a transmission cooler to start and may move to gear set spray bar over time. I have read that the mesh point of the gears is where to aim the cool oil sprays, not sure this is correct. I appreciate any advice people have. John |
FourBlades |
Aug 6 2021, 04:13 PM
Thanks for the great replies everyone! Seems like the 901 should last a while with the right upgrades. Love the gear ratio chart @slivel! I plan to run the same cooling pump and radiator that were in the car when I got it. Adding a spray to the diff seems like an easy upgrade and maybe a couple more, like 3rd, 4th, 5th gears. Do most people use -10 AN lines? If I use the billet intermediate plate, do I need to reset the pinion depth? That is a big question. If not, then I think it is a no brainer to get it. Maybe the 108mm CVs from the 930 are overkill? Maybe the 100mm CVs would be enough? John |
Lo-Fi Version | Time is now: 17th May 2024 - 05:18 PM |
