What HP level requires transmission upgrades?, I have 200 HP to the wheels, what do I need? |
FourBlades |
Aug 6 2021, 09:42 AM
From Wreck to Rockin Group: Members Posts: 2,054 Joined: 3-December 07 From: Brevard, FL Member No.: 8,414 Region Association: South East States |
I realize it is probably torque that kills a transmission, but I don't know the torque output of my engine.
I am building a 901 transmission for my IMSA 914 and wonder what upgrades it will need. I have some possible upgrades I could do now. First, I have a set of 930 stub axles, CVs and the corresponding sway-away axles for a 914. They are stronger and the CVs are available for $80 from pelican. Downside is I have to destroy the existing rear bearings in my axles to use them, which were rebuilt by PMB. If I have 200 HP to the wheels are the 930 CVs a necessary or worthwhile upgrade? Second, should I upgrade to the billet intermediate plate at this HP level? If I do, will I have to reset the pinion depth? That is something I can't do myself and would need to find a shop here in Florida that can do it. I know this is overkill for a typical 914, but with 12 inch rear tires and a 2.5L six, is this when the upgrade is worth while? I am not adverse to starting with the 914 axles and upgrading down the road. Pulling the engine and transmission is not that time consuming. I would hate to break the smaller axles or CVs the first time at the track though. I have a stock gearset and know there are probably better gear choices for Sebring, Daytona, etc. No idea where to start with those. I will be running a transmission cooler to start and may move to gear set spray bar over time. I have read that the mesh point of the gears is where to aim the cool oil sprays, not sure this is correct. I appreciate any advice people have. John |
brant |
Aug 13 2022, 05:26 PM
914 Wizard Group: Members Posts: 11,624 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
I think that high rpm also has an impact on transmission life in addition to hp and torque
I never had trans problems with my old race -4 But the 2.0/6 has a much higher red line I do not think the trans bearings love 7 or 8k More rpm creates more heat |
stownsen914 |
Aug 14 2022, 09:17 AM
Horsepower can be managed with cooling. Torque can exceed the physical strength of parts, cooling can't help with that.
Interesting point about RPM. I've assumed that also can be managed with cooling, don't have any data to support that though. |
Lo-Fi Version | Time is now: 17th May 2024 - 02:39 PM |
