Glue for the knee pad bolster, What is safe to use? |
seanpaulmc |
Aug 7 2021, 02:30 PM
Member Group: Members Posts: 300 Joined: 6-December 16 From: Orlando, FL Member No.: 20,649 Region Association: South East States |
In working on the steering column I've removed the knee pad bolster from the dash. Overall it is in decent condition surprisingly but has does need some TLC in a few spots. There are a couple of spots where the vinyl is coming apart. And, the chrome strip needs to be reattached in a couple of areas.
Is there a recommended type of glue or adhesive to use on this vinyl / foam assembly? Same for the chrome strip where it is pulling out. Thank you, Sean |
windforfun |
Aug 7 2021, 05:35 PM
Senior Member Group: Members Posts: 1,790 Joined: 17-December 07 From: Blackhawk, CA Member No.: 8,476 Region Association: None |
Buy a new (used) one that's clean & plug & play. If you do find the right adhesive, can you clamp the part properly? Contact cement will perhaps eliminate the need for clamping.
Lo-Fi Version | Time is now: 19th May 2024 - 08:35 AM |
