Turn Signal Indicator Always On, I Really Do Have A Problem |
Ansbacher |
Aug 11 2021, 05:40 PM
Senior Member Group: Members Posts: 689 Joined: 4-July 14 From: Tampa Bay, Florida Member No.: 17,589 |
Car = '74 2.0
Well, my last post was premature on this, but I really do have a problem with my turn signal indicator. Here it is: My signal indicator has never worked. Found no indicator bulbs in the sockets inside the the tach gauge, so I installed the correct 2 watt bulbs. Now, with the key in the on or start position, the indicators are always lit. If you signal left or right they both pulsate. The car's actual blinkers function fine. I now understand why the P.O. removed the indicator bulbs. Any idea why this is happening? Is it in the column switch? Thanks. Ansbacher |
Lo-Fi Version | Time is now: 29th May 2024 - 07:01 AM |
