Need to raise the front a bit, Can I use the adjuster on the front |
aircooledboy |
Jul 25 2005, 12:46 PM
Sweet Pea's 1st ride in daddy's "vroom -vroom" Group: Members Posts: 1,672 Joined: 4-February 04 From: Rockford, IL Member No.: 1,629 Region Association: Upper MidWest |
My front suspension is a just too damn low. Even with an LE air dam on the front, I routinely catch it on the ground pulling out of parking lots, but more importantly, on a near full right turn the right tire hits the fender lip AND the inside back edge rubs on my AC hoses inside the wheel well. I just replaced one AC hose, remounted the hose higher in a spot I thought was out of the way, and it's still freakin hitting. (IMG:http://www.914world.com/bbs2/html/emoticons/mad.gif)
I want to raise it 1/4" to 1/2" or so. Can I do that with the adjusters on the front of the torsion bars, or will that fuch things up somewhere else. (IMG:http://www.914world.com/bbs2/html/emoticons/beerchug.gif) |
davep |
Jul 25 2005, 12:50 PM
914 Historian Group: Benefactors Posts: 5,151 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
The adjusters are there for that purpose. If you run out of threads, then remove and rotate the cap by a spline. You may need to do an alignment afterwards though.
Jul 25 2005, 01:02 PM
Resident German Group: Admin Posts: 41,669 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
(IMG:http://www.914world.com/bbs2/html/emoticons/agree.gif) i frequently change the ride-heigth about 1/2" (lower for AX, higher for street) ... so far, i haven't felt the need for re-aligning the frontend, on both settings the car seems to behave the same at high speeds and cornering (except the understeer/oversteer thing, of course) ... (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) Andy |
John2kx |
Jul 25 2005, 01:22 PM
Senior Member Group: Members Posts: 502 Joined: 22-August 03 From: Augusta, Ga. Member No.: 1,066 |
Chris,
You should have no problem making this adjustment. I lowered it about 1/2" to get the attitude it is at right now. As far as alignment goes, drive it after the adjustment and see if you feel any changes, I doubt you will if your still using it as a street cruiser. I advise making your adjustments after taking initial measurements from donuts. Then, make change, roll car forward and back several feet and make same change to other side. Go for a drive and measure donuts again to check for equal rise on both sides. John |
aircooledboy |
Jul 25 2005, 01:34 PM
You guys rock. (IMG:http://www.914world.com/bbs2/html/emoticons/beerchug.gif)
I thought the above was correct, just wanted to be sure. John, great to see you more active around here again. Shockingly enough, car hasn't gotten painted yet. BUT, last thursday I met with the guy who's going to do the work this winter, and we agreed on a price and a schedule. Custom flares, custom rear valance and a full repaint. He'll have it all winter, and come spring, MWHOOOOHAHAHAHAHA!!!, she'll look like she drives. (IMG:http://www.914world.com/bbs2/html/emoticons/boldblue.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/monkeydance.gif) |
Jul 25 2005, 01:35 PM
914 Idiot Group: Members Posts: 14,991 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
Raising the front of the car will take some negative camber out of the wheels--or add some positive camber, if you want to look at it that way. 1/2" shouldn't change it that much, though. It will also probably affect the toe angle, but again I doubt it will be enough to cause problems. If you want to be certain, though, you should get it checked again when you're done.
Or set up some strings and do the DIY alignment thing on your own! --DD |
aircooledboy |
Jul 27 2005, 10:01 AM
Mission accomplished. WHOLEY CRAP does it ride better. (IMG:http://www.914world.com/bbs2/html/emoticons/boldblue.gif)
First thing I found was that the right was about 3/8 lower than the left already. Raised both sides until I was 5 1/2 at the doughnut on both sides. I was surprised how adjusting one side made a big difference on the other side. Was a little frustrating, but I got them even after some effort. I expected the raise to soften out the ride some, but WOW, what a pleasant surprise. Rolling over a good sized crack in the road used to rearrange your innerds a bit, now, it's just a crack. The drive to the MWC just got a lot more inviting. (IMG:http://www.914world.com/bbs2/html/emoticons/beerchug.gif) |
Lo-Fi Version | Time is now: 31st May 2024 - 10:06 PM |
