| SirAndy |
Jul 25 2005, 01:10 PM
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,565 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
so on my way to the AX saturday i noticed a "clunk" sound from the frontend, like i had lost something.
i had this happen before, bolt came lose on the swaybar droplink, so i thought that was it ... when i get to the AX site and change tires, i see the droplink hanging all weird so i take a closer look and the lower hime joint has broken. the thread just snapped off the joint. i then continue to change the tire on the other side and it's exactly the same! (IMG:http://www.914world.com/bbs2/html/emoticons/ohmy.gif) both hime joints broke in the exact same location. that seems too odd to be coincidence. i must have hit something *really* hard for that to happen, but i can't remember running over any bad potholes etc. anyone else had problems before? (IMG:http://www.914world.com/bbs2/html/emoticons/unsure.gif) Andy |
SirAndy tarett swaybar stuff broke ... Jul 25 2005, 01:10 PM
Cloudbuster Didn't you weld on the u-tabs rotated 90 degre... Jul 25 2005, 01:18 PM
ArtechnikA my rant on "everybody else's" 8mm-5/16" dropli... Jul 25 2005, 01:25 PM
Dave_Darling http://www.914world.com/bbs2/... Jul 25 2005, 01:38 PM
ChrisReale ... Aug 2 2005, 10:05 PM
Ira Ramin Andy,
Your explanation makes full sense, and I’v... Aug 3 2005, 11:27 PM
Dave_Darling Now, that, my friends, is what I call Customer Ser... Aug 3 2005, 11:53 PM
McMark Way to go IRA! Your stock just jumped big tim... Aug 4 2005, 01:27 AM
SteveSr I was considering a Tarett bar for my car,now I kn... Aug 4 2005, 08:45 AM
Series9 Yep, that'll do it for me too. The RS is gett... Aug 4 2005, 09:25 AM
Mueller Aug 4 2005, 09:30 AM
Series9 Aug 4 2005, 09:45 AM
Mueller Aug 4 2005, 09:55 AM
Series9 I see. Well that sucks.
I had already pretty muc... Aug 4 2005, 09:59 AM
ArtechnikA all about the same; if you really want to support ... Aug 4 2005, 10:08 AM
SirAndy alright, let me say first that i really apprechiat... Aug 4 2005, 12:45 PM
SirAndy drivers side:
note how the hime joint is stuck al... Aug 4 2005, 12:49 PM
SirAndy pass side:
same here, hime joint was stuck toward... Aug 4 2005, 12:53 PM
SirAndy and out of the car ...
http://www.914world.com/bb... Aug 4 2005, 12:54 PM
Mueller I wonder if moving the link out .25" to .375" woul... Aug 4 2005, 12:55 PM
SirAndy so it looks like all i need is two lower hime-join... Aug 4 2005, 12:57 PM
SirAndy Aug 4 2005, 12:59 PM
J P Stein I've been running Ira's bar in the front o... Aug 4 2005, 01:00 PM
SirAndy ... Aug 4 2005, 01:06 PM
Dave_Darling Pics of the actual failure site may be able to tel... Aug 4 2005, 01:13 PM
SirAndy Aug 4 2005, 01:38 PM
Cloudbuster I figure the lower heim joint broke off while it w... Aug 4 2005, 02:00 PM
airsix Aug 4 2005, 02:22 PM
Mueller how about having 2 sets of U-tabs? Aug 4 2005, 02:29 PM
Dave_Darling It's tough to tell from the pics (mostly due t... Aug 4 2005, 02:49 PM
john rogers Has anyoner snapped a bolt off? Remember what hepp... Aug 4 2005, 03:10 PM
airsix I don't think heim joints are compatible with ... Aug 4 2005, 03:13 PM
Cloudbuster Even if the droplink is shortened, the mounting po... Aug 4 2005, 03:53 PM
jkeyzer Maybe the solution is a different diameter bar???
... Aug 4 2005, 04:04 PM
SirAndy i like the idea of U-Tabs that are simply wider pl... Aug 4 2005, 04:07 PM
SirAndy Aug 4 2005, 04:08 PM
Demick Aug 4 2005, 04:15 PM
Demick Another consideration is that the lower heim joint... Aug 4 2005, 04:20 PM
SirAndy here's another observation ....
the way the t... Aug 4 2005, 04:23 PM
SirAndy Aug 4 2005, 04:24 PM
Demick Aug 4 2005, 04:31 PM
SirAndy Aug 4 2005, 04:34 PM
jonwatts Is our application different than a 911? I'm c... Aug 4 2005, 04:35 PM
john rogers The upper mount being tight against the sway bar i... Aug 4 2005, 04:39 PM
SirAndy Aug 4 2005, 05:26 PM
SirAndy Aug 4 2005, 05:38 PM
Cloudbuster The problem is that the upper heim joint is fixed ... Aug 4 2005, 05:47 PM
McMark Did the heim joint run into the UTab or the spacer... Aug 4 2005, 06:08 PM
SirAndy Aug 4 2005, 06:14 PM
McMark On the bottom. The top seems irrelevant, since it... Aug 4 2005, 06:27 PM
SirAndy Aug 4 2005, 06:29 PM
Demick Aug 4 2005, 07:10 PM
Ira Ramin Lets keep in mind that my picture is with my u-tab... Aug 4 2005, 07:20 PM
jonwatts I wonder if this is all just a matter of the facto... Aug 4 2005, 07:24 PM
SirAndy Aug 4 2005, 07:47 PM
SirAndy ... Aug 4 2005, 07:57 PM
SirAndy sideways Aug 4 2005, 07:58 PM
Demick <... Aug 4 2005, 07:59 PM
Demick so clearly the heim hit the spacers before hitting... Aug 4 2005, 08:01 PM
SirAndy Aug 4 2005, 08:02 PM
Cloudbuster It looks as if those u-tabs ARE too far inboard. ... Aug 4 2005, 08:27 PM
Eric_Shea Those U-Tabs look to be about 1/2" too far inward ... Aug 4 2005, 08:31 PM
SirAndy ... Aug 4 2005, 08:35 PM
SirAndy Aug 4 2005, 10:34 PM
trekkor ![]() ![]() |
Lo-Fi Version | Time is now: 27th November 2026 - 03:56 AM |
