2056 Dellorto question |
jmargush |
Aug 28 2021, 03:49 PM
Member Group: Members Posts: 460 Joined: 8-June 04 From: Goshen, IN Member No.: 2,176 |
I am in the process of getting a freshly rebuilt 2056 up and running.
9590 Raby cam Dellorto 40 with the CB performance upgrade kit Is there any consensus are 40's big enough for this engine? I am having a hard time getting it to idle and come off throttle. I have the largest idle jets in the carbs and I am still getting popping out of the carbs. I checked float levels today and they are good. Waiting on more jet combinations to arrive next week. Any more thoughts on things to check? |
nditiz1 |
Aug 28 2021, 04:24 PM
Senior Member Group: Members Posts: 1,188 Joined: 26-May 15 From: Mount Airy, Maryland Member No.: 18,763 Region Association: MidAtlantic Region |
36s should be plenty big enough. If you are running 40s what are your current specs?
In order to properly jet/tune you should really have an afr. |
barefoot |
Aug 28 2021, 04:40 PM
Senior Member Group: Members Posts: 1,274 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States |
What idle 7 mani jets & venturi's are you running ?
jmargush |
Aug 28 2021, 05:28 PM
.75 idle
1.65 mail 1.7 air correction jet .5 pump jet I think the venturis are 36 |
anderssj |
Aug 28 2021, 07:45 PM
Dog is my copilot... Group: Members Posts: 1,656 Joined: 28-January 03 From: VA Member No.: 207 Region Association: MidAtlantic Region |
just for comparison, my car has DRLA 40s set up with 30mm main venturis, 55 idle jets, 135 main jets, 180 air correction jets, and 9164.2 emulsion tubes. I know these are a little smaller than the factory settings, but they seem to work well with the current engine build (914 2.0L, Elgin 7008-4 cam [280* duration, .332 lobe lift], Mahle Euro PC set [8.0:1]). Car has run great with this set up for almost 100K miles (I made some adjustments for altitude when stationed in Colorado Springs)
What is the CB Performance upgrade kit? |
jmargush |
Aug 29 2021, 03:59 AM
CB Upgrade kit is smaller venturis and different idle jet setup. This I'm told totally changes the jet set up.
What you're running sounds like what I'm told a stock 40 would run. I might need to go back and change the carbs to the stock configuration. |
Shivers |
Aug 29 2021, 06:53 AM
Senior Member Group: Members Posts: 2,378 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California |
CB Upgrade kit is smaller venturis and different idle jet setup. This in told totally changes the jet set up. What you're running sounds like what I'm told a stock 40 would run. I might need to go back and change the carbs to the stick configuration. The upgrade kit for 40 webers gave me larger venturis along with the spray bars and jets. 44 webers have a 34 venturi to start with, and your dells are 36's like mine. Unless you ordered something different. |
GregAmy |
Aug 29 2021, 07:48 AM
Advanced Member Group: Members Posts: 2,302 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States |
....and I am still getting popping out of the carbs. That is an indication of plugged idle ports/jets. It's a known, common problem with Dells, as the air intake of the idles is on the "floor" of the top. Pull the idle jets, ensure they're clean, and then blow out the idle ports. Then ensure you have a good clean air cleaner assembly. This was a common problem in sandrails and such. CB Performance makes a kit that raises the air intake above the floor. I have it, but have only installed the larger venturis: https://www.cbperformance.com/product-p/7345.htm I have a strong 2056 race engine (86A cam?) with 40 Dells and we'll be at Lime Rock next weekend. We're gonna spend the weekend jetting/re-jetting. Right now we're at: CB 36mm venturis 1.80 air correction 1.70 mains .7 idles .65 accel Idle is way too fat, around 11, but full throttle through the power range is good, around 12.7-12.9. After the weekend we'll play with it and see where we end up. Remind me after Labor Day for an update. Greg |
jmargush |
Aug 29 2021, 10:33 AM
CB Upgrade kit is smaller venturis and different idle jet setup. This in told totally changes the jet set up. What you're running sounds like what I'm told a stock 40 would run. I might need to go back and change the carbs to the stick configuration. The upgrade kit for 40 webers gave me larger venturis along with the spray bars and jets. 44 webers have a 34 venturi to start with, and your dells are 36's like mine. Unless you ordered something different. I am not totally sure these carbs are from the guy who rebuilt my engine so I'll have to measure them to be certain |
Shivers |
Aug 29 2021, 10:43 AM
CB Upgrade kit is smaller venturis and different idle jet setup. This in told totally changes the jet set up. What you're running sounds like what I'm told a stock 40 would run. I might need to go back and change the carbs to the stick configuration. The upgrade kit for 40 webers gave me larger venturis along with the spray bars and jets. 44 webers have a 34 venturi to start with, and your dells are 36's like mine. Unless you ordered something different. I am not totally sure these arbs are from the guy who rebuilt my engine so I'll have to measure them to be certain I'm no expert, but I believe your engine will breathe just fine, with an exhaust that will allow it to. |
jmargush |
Aug 29 2021, 10:49 AM
....and I am still getting popping out of the carbs. That is an indication of plugged idle ports/jets. It's a known, common problem with Dells, as the air intake of the idles is on the "floor" of the top. Pull the idle jets, ensure they're clean, and then blow out the idle ports. Then ensure you have a good clean air cleaner assembly. This was a common problem in sandrails and such. CB Performance makes a kit that raises the air intake above the floor. I have it, but have only installed the larger venturis: https://www.cbperformance.com/product-p/7345.htm I have a strong 2056 race engine (86A cam?) with 40 Dells and we'll be at Lime Rock next weekend. We're gonna spend the weekend jetting/re-jetting. Right now we're at: CB 36mm venturis 1.80 air correction 1.70 mains .7 idles .65 accel Idle is way too fat, around 11, but full throttle through the power range is good, around 12.7-12.9. After the weekend we'll play with it and see where we end up. Remind me after Labor Day for an update. Greg Interesting Not sure how close the 86A cam is but looks like the direction I am heading. So I am assuming the Id of the barrel in the carb is the venturi and these measure to be 36mm. These have the raised idle jets. I'll try cleaning the ports as I only cleaned the jets yesterday. I'll be interested to hear how your Lime Rock weekend goes Attached thumbnail(s) |
jmargush |
Aug 29 2021, 10:50 AM
CB Upgrade kit is smaller venturis and different idle jet setup. This in told totally changes the jet set up. What you're running sounds like what I'm told a stock 40 would run. I might need to go back and change the carbs to the stick configuration. The upgrade kit for 40 webers gave me larger venturis along with the spray bars and jets. 44 webers have a 34 venturi to start with, and your dells are 36's like mine. Unless you ordered something different. I am not totally sure these arbs are from the guy who rebuilt my engine so I'll have to measure them to be certain I'm no expert, but I believe your engine will breathe just fine, with an exhaust that will allow it to. It has a set of Tangerine Racing headers so it should be breathing about good as it can. |
jmargush |
Aug 29 2021, 03:38 PM
Pulled the carbs off and sprayed and blew everything out.
Now it at least idles a bit on the low side but better than it was. I might need to go back and clean the pump jets as it isn't coming off idle very well. I do get a squeaking or tweeting when accelerating, anyone have any ideas on what this might be? |
nditiz1 |
Aug 29 2021, 04:57 PM
Dellorto whistle is common, nothing to be concerned about.
jmargush |
Aug 29 2021, 05:12 PM
....and I am still getting popping out of the carbs. That is an indication of plugged idle ports/jets. It's a known, common problem with Dells, as the air intake of the idles is on the "floor" of the top. Pull the idle jets, ensure they're clean, and then blow out the idle ports. Then ensure you have a good clean air cleaner assembly. This was a common problem in sandrails and such. CB Performance makes a kit that raises the air intake above the floor. I have it, but have only installed the larger venturis: https://www.cbperformance.com/product-p/7345.htm I have a strong 2056 race engine (86A cam?) with 40 Dells and we'll be at Lime Rock next weekend. We're gonna spend the weekend jetting/re-jetting. Right now we're at: CB 36mm venturis 1.80 air correction 1.70 mains .7 idles .65 accel Idle is way too fat, around 11, but full throttle through the power range is good, around 12.7-12.9. After the weekend we'll play with it and see where we end up. Remind me after Labor Day for an update. Greg Greg man wish i could make a trip to Lime Rock Never been and would be cool to watch you test and tune. Any idea what difference 1.8 vs. 1.7 air correction jets will do? I'll check with you after labor day ? |
nditiz1 |
Aug 29 2021, 05:52 PM
Larger airs bring in the main sooner. Smaller will bring them in later. What you are looking for is a good balance of brining in the main when the idle circuit drops off. Your idles are way to large. To get the feel of the idle jets take the main stack out and drive the car around. You will know when the mains will kick in as the car will fall on its face. I would go with the base above with 55 idles. Venturi are your powerband. Larger will allow you to still feel power at higher rpms. 28s maybe 30s should be right for that engine.
porschetub |
Aug 29 2021, 11:05 PM
Advanced Member Group: Members Posts: 4,699 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Pulled the carbs off and sprayed and blew everything out. Now it at least idles a bit on the low side but better than it was. I might need to go back and clean the pump jets as it isn't coming off idle very well. I do get a squeaking or tweeting when accelerating, anyone have any ideas on what this might be? You need to look @ the venturies ,they have a number on the casting,it should be 28 or possibly up to 32 for your carbs (40 drla) the bore of the carb will be 36mm most likely but that's not the number you are after (IMG:style_emoticons/default/sad.gif) Have no experience with this conversion but Dells are very easy to tune,make sure you have a good clean regulated fuel supply @ around 3psi ,good luck. |
ndfrigi |
Aug 30 2021, 01:29 AM
jmargush |
Aug 30 2021, 04:45 AM
Larger airs bring in the main sooner. Smaller will bring them in later. What you are looking for is a good balance of brining in the main when the idle circuit drops off. Your idles are way to large. To get the feel of the idle jets take the main stack out and drive the car around. You will know when the mains will kick in as the car will fall on its face. I would go with the base above with 55 idles. Venturi are your powerband. Larger will allow you to still feel power at higher rpms. 28s maybe 30s should be right for that engine. When I have had smaller idle jets in it pops indicating its lean, right? Just to understand, you are recommending 1.8 air 1.7 main .65 pump .55 idle and change to 28 or 30 venturi if that is not what I have |
jmargush |
Aug 30 2021, 05:11 AM
Lo-Fi Version | Time is now: 17th May 2024 - 07:12 PM |
