2056 Dellorto question |
yeahmag |
Aug 30 2021, 12:14 PM
Advanced Member Group: Members Posts: 2,422 Joined: 18-April 05 From: Pasadena, CA Member No.: 3,946 Region Association: Southern California |
My set up with a 2056cc, 86A, crappy E10 gas, 9.5:1 (to help with E10), lot's of custom crap... It's a pretty fast autocross car for it's displacement.
Dual 40 Dells 36 vents 160 main 180 air 62 idle 35 pump 5-12 floats, vertical 250 inlet valve 30 degrees advance I've gone through 10 variations on the 36mm venturi, all tuned with an LM-2. |
jmargush |
Aug 30 2021, 06:46 PM
Member Group: Members Posts: 460 Joined: 8-June 04 From: Goshen, IN Member No.: 2,176 |
My set up with a 2056cc, 86A, crappy E10 gas, 9.5:1 (to help with E10), lot's of custom crap... It's a pretty fast autocross car for it's displacement. Dual 40 Dells 36 vents 160 main 180 air 62 idle 35 pump 5-12 floats, vertical 250 inlet valve 30 degrees advance I've gone through 10 variations on the 36mm venturi, all tuned with an LM-2. Educate me a little What do you mean by 5-12 float, vertical? and 250 inlet valve? mine falls on itself with quick throttle with 35 pump lots of popping if idel jets are smaller than 70. |
yeahmag |
Sep 1 2021, 10:28 AM
When setting the float level, holding the carb top vertical (as to not engage the spring on the inlet needle valve) I set it at 5mm. 12mm is the full droop. Inlet valves come in sizes just like jets. I use the biggest one I can get to help keep the carbs from starving and make less work for my fuel pump.
What are your ignition settings? Are you popping out the exhaust or out the carbs? Have you verified that all 4 accelerator pumps are working? Rebuilt the carbs recently (full cleaning and new gaskets including pump diaphram)? What are your idle volume control screws set at (this can be indicative of a lean or rich environment) and how do they "react" to changes? |
rhodyguy |
Sep 1 2021, 10:54 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,084 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
I think you will be happier using 32mm vents on your 2056. Shoot for a 950rpm idle.
jmargush |
Sep 2 2021, 01:03 PM
When setting the float level, holding the carb top vertical (as to not engage the spring on the inlet needle valve) I set it at 5mm. 12mm is the full droop. Inlet valves come in sizes just like jets. I use the biggest one I can get to help keep the carbs from starving and make less work for my fuel pump. What are your ignition settings? Are you popping out the exhaust or out the carbs? Have you verified that all 4 accelerator pumps are working? Rebuilt the carbs recently (full cleaning and new gaskets including pump diaphram)? What are your idle volume control screws set at (this can be indicative of a lean or rich environment) and how do they "react" to changes? So is the inlet valve the fitting where the fuel lines attach? Not sure what the timing is Carbs are in good shape and clean Pump jets are working Idle mixture screws don't seem to have a lot of impact on changing which CB Performance told me that is a sign the idle jets are too big, but with smaller jets it pops out the carbs |
jmargush |
Sep 2 2021, 01:05 PM
When setting the float level, holding the carb top vertical (as to not engage the spring on the inlet needle valve) I set it at 5mm. 12mm is the full droop. Inlet valves come in sizes just like jets. I use the biggest one I can get to help keep the carbs from starving and make less work for my fuel pump. What are your ignition settings? Are you popping out the exhaust or out the carbs? Have you verified that all 4 accelerator pumps are working? Rebuilt the carbs recently (full cleaning and new gaskets including pump diaphram)? What are your idle volume control screws set at (this can be indicative of a lean or rich environment) and how do they "react" to changes? So when you are holding the carb vertical and you set the 5mm gap are you pushing the the float closed or just letting it rest? |
jmargush |
Sep 3 2021, 04:58 AM
When setting the float level, holding the carb top vertical (as to not engage the spring on the inlet needle valve) I set it at 5mm. 12mm is the full droop. Inlet valves come in sizes just like jets. I use the biggest one I can get to help keep the carbs from starving and make less work for my fuel pump. What are your ignition settings? Are you popping out the exhaust or out the carbs? Have you verified that all 4 accelerator pumps are working? Rebuilt the carbs recently (full cleaning and new gaskets including pump diaphram)? What are your idle volume control screws set at (this can be indicative of a lean or rich environment) and how do they "react" to changes? So is the inlet valve the fitting where the fuel lines attach? Not sure what the timing is Carbs are in good shape and clean Pump jets are working Idle mixture screws don't seem to have a lot of impact on changing which CB Performance told me that is a sign the idle jets are too big, but with smaller jets it pops out the carbs Never mind on the inlet question I see now that is the needle and seat |
Lo-Fi Version | Time is now: 1st June 2024 - 12:48 PM |
