Anyone have experience with these aftermarket injectors? |
Halfnelson |
Sep 2 2021, 11:18 AM
Newbie Group: Members Posts: 46 Joined: 31-July 17 From: Cornwall Member No.: 21,303 Region Association: England |
Anyone have experience with these injectors? I have them fitted to my recently acquired 73 1.7 with standard Djet.
My car is currently running very rich / flooding and the injectors are heading to a local specialist for testing as we suspect one of them is sticking. The alternative is they are the wrong spec for the car. Anyone else run them? https://www.fiveomotorsport.com/hose-type-e...ro-asian-sport/ They are the 380cc type. Thanks, Chris |
emerygt350 |
Sep 2 2021, 11:57 AM
Advanced Member Group: Members Posts: 2,096 Joined: 20-July 21 From: Upstate, NY Member No.: 25,740 Region Association: North East States |
Nice you figured out what they are. That is almost 100cc too much for a 1.7.
914sgofast2 |
Sep 2 2021, 07:08 PM
Senior Member Group: Members Posts: 617 Joined: 10-May 13 From: El Dorado Hills, CA Member No.: 15,855 Region Association: None |
I believe that green top injectors are for the 1.8liter engines. The yellow top ones are for the 1.7 liter engines.
Quinn Moore |
Sep 2 2021, 07:31 PM
Qmoore Group: Members Posts: 107 Joined: 13-July 21 From: Fox River Grove, IL Member No.: 25,718 Region Association: Upper MidWest |
Anyone have experience with these injectors? I have them fitted to my recently acquired 73 1.7 with standard Djet. My car is currently running very rich / flooding and the injectors are heading to a local specialist for testing as we suspect one of them is sticking. The alternative is they are the wrong spec for the car. Anyone else run them? https://www.fiveomotorsport.com/hose-type-e...ro-asian-sport/ They are the 380cc type. Thanks, Chris Green 2.0, yellow 1.7? Replacement , I put these in my 2.0 while the Bosch we're sent out for service. Fj67 worked well. No issues. Add the seal kit. Maybe check the FJ114? 2.0 standard FJ67 https://www.rockauto.com/en/parts/standard+...l+injector,6224 1.7 standard ( FJ114. 1.7) https://www.rockauto.com/en/catalog/porsche...l+injector,6224 |
914sgofast2 |
Sep 2 2021, 08:29 PM
I have been using those Rock Auto sourced FJ114 fuel injectors on my 1.7 Liter for several years and am very happy with them.
Halfnelson |
Sep 3 2021, 07:27 AM
Nice you figured out what they are. That is almost 100cc too much for a 1.7. OK, that would account for our inability to trace the rich running / flooding. I did see in correspondence from the PO that the supplier claimed they were compatible with a 914 1.7 Djet. I was hoping maybe that one or more of the injectors were either sticky or leaky but I guess what you're suggesting is they're not compatible at all. |
Sep 3 2021, 01:23 PM
No, they are compatible--they spray a metered amount of fuel just fine.
It's just that it's the wrong amount for a 1.7 engine. They can probably be made to inject the right amount for a 1.7, but it will require work to the rest of the FI. It's a fine difference between "compatible" and "correct", but it's there. Especially if you are selling the parts. --DD |
Halfnelson |
Sep 4 2021, 04:16 AM
No, they are compatible--they spray a metered amount of fuel just fine. It's just that it's the wrong amount for a 1.7 engine. They can probably be made to inject the right amount for a 1.7, but it will require work to the rest of the FI. It's a fine difference between "compatible" and "correct", but it's there. Especially if you are selling the parts. --DD Thanks Dave - would this be a complex way of doing things or would it be simple ie tweaking fuel pressure? I would need to order replacement injectors from the US so that would take a while so if tweaking is relatively straightforward that would be an option for sure. What is the correct metered about a 1.7 injector should deliver? |
sholman5 |
Sep 4 2021, 07:59 AM
Kraut burner Group: Members Posts: 189 Joined: 11-September 16 From: Ormond beach, Fl. Member No.: 20,391 Region Association: South East States |
Robarabian |
Sep 5 2021, 05:51 PM
914 A Roo Group: Members Posts: 592 Joined: 11-February 19 From: Simi Valley, Kalifornia Member No.: 22,865 Region Association: Southern California |
Dave,
I am pumping up my 1.7 to a 1911 in my rebuild. Would the 2.0 injector work in that situation... its closer to 2 liter, but still running off the 1.7 brain and other parts. I am afraid the 1.7 injectors will run lean. Any info would be great. Thanks. No, they are compatible--they spray a metered amount of fuel just fine. It's just that it's the wrong amount for a 1.7 engine. They can probably be made to inject the right amount for a 1.7, but it will require work to the rest of the FI. It's a fine difference between "compatible" and "correct", but it's there. Especially if you are selling the parts. --DD |
Lo-Fi Version | Time is now: 17th May 2024 - 07:24 PM |
