Porsche 914 engine fan, Engine Fan Air Intake Screen? |
Str1974 |
Sep 2 2021, 12:17 PM
Member Group: Members Posts: 90 Joined: 23-January 19 From: Dallas Member No.: 22,820 Region Association: Southwest Region |
Hello All, I've currently dropped my engine (Yes, my first time on my own..) in order to replace my oil cooler and clean up my engine tins and repaint, etc. I removed my engine fan to clean up as well, and was wondering why the 914 engine does not use the intake screen that other type 4 bus engine uses? I realize the bus engine has it that it is accessible from rear engine lid and therefore you don't want to loose your fingers by sticking your hand into the fan.... but other than making it harder to replace the fan belt from the back of the 914 compartment, has anyone decided that in order to prevent a wrench or other tool fall down the back of the 914 engine compartment and get feed into the fan the screen could protect accidents from happening. Any thoughts? Any reason for the screen to make any negative cooling effects on 914 fan intake? Just curious and thinking about putting on screen....
GregAmy |
Sep 2 2021, 12:30 PM
Advanced Member Group: Members Posts: 2,302 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States |
It's protected from road debris by the engine tin.
I put one on both my cars anyway. Mostly to keep ME from dropping something in there. |
914Sixer |
Sep 2 2021, 01:08 PM
Yeah, good idea for self preservation. Over the years interesting stuff has made it into fan housing. (IMG:style_emoticons/default/headbang.gif)
Dustin |
Sep 2 2021, 01:59 PM
Member Group: Members Posts: 111 Joined: 19-August 10 From: Woodland Hills, CA Member No.: 12,072 Region Association: None |
The fan is at the front of the 914 engine compartment. Not the back. That could be why the screen doesn't get installed. Someone would actually try to put their hand in the fan on a 914. On a bus the fan is facing the person working on the engine.
wonkipop |
Sep 2 2021, 07:30 PM
Advanced Member Group: Members Posts: 4,300 Joined: 6-May 20 From: north antarctica Member No.: 24,231 Region Association: NineFourteenerVille |
kombis were double dangerous.
hippies could get their kaftans sucked into the fan while mesmerized by the prayer wheel they had painted on the blades? vw service personal weren't paid danger money and instructed on the proper use of tie clips like 911 technicians? pure safety thing on kombi version. bit like leaning over the radiator of a 1960s australian ford falcon? ducting and shrouds on type 1 and type 3 as well as regular 411/12s make death by strangulation from loose clothing impossible. only the kombi is lethal at tune up time - esp twin carb variety where you have a screw driver in each carb and anything is dangling. |
emerygt350 |
Sep 2 2021, 10:16 PM
Advanced Member Group: Members Posts: 2,096 Joined: 20-July 21 From: Upstate, NY Member No.: 25,740 Region Association: North East States |
Just the other day I was working on mine and a screw dropped down there. At first, I was like 'whatever', then I realized the true danger and scared the crap out of my 8 year old son when I started appreciating the full implications of my problem. I got the screw back, my son is still recovering.
jcd914 |
Sep 3 2021, 01:06 AM
The big side air ducts on the bus could pull in much bigger things than the 914 engine lid would let in. As both a dealer VW tech and dealer Porsche tech, I got more safety training from VW than Porsche, although all the training was in the same 2 training centers. Jim |
Mark Henry |
Sep 3 2021, 12:01 PM
Try changing a fan belt in a 914 with a screen...then you'll wish you hadn't.
johnhora |
Sep 3 2021, 03:53 PM
Senior Member Group: Members Posts: 866 Joined: 7-January 03 From: Derby City KY Member No.: 107 Region Association: None |
(IMG:style_emoticons/default/agree.gif) with Mark
Think food disposal in your sink...a 914 T-4 fan will eat just about anything that goes in there |
jim_hoyland |
Sep 3 2021, 04:07 PM
Get that VIN ? Group: Members Posts: 9,301 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
I got mine from Bus Depot:
https://www.busdepot.com/j10983 |
pt_700 |
Sep 3 2021, 05:02 PM
Senior Member Group: Members Posts: 1,092 Joined: 4-March 10 From: san jose, ca Member No.: 11,430 Region Association: Northern California |
one of my heater hoses came loose and got sucked into there...
wonkipop |
Sep 3 2021, 05:06 PM
The big side air ducts on the bus could pull in much bigger things than the 914 engine lid would let in. As both a dealer VW tech and dealer Porsche tech, I got more safety training from VW than Porsche, although all the training was in the same 2 training centers. Jim ahh that would explain it - absolutely. (IMG:style_emoticons/default/beerchug.gif) all the vws down here ran twin carbs on type3s and kombis (very few fuel injected). can still remember being arse up head down in the back of the square back with a stub screwdriver in each carb balancing the idle and trying to get the linkages tuned!. good thing it didn't have a type 4 fan spinning away right were my t- shirt would be hanging down. ------- if you look at later cars with smog pumps, or even a 912e running ac and smog pump off fan as a pulley, a screen is impossible. |
wonkipop |
Sep 3 2021, 05:35 PM
Just the other day I was working on mine and a screw dropped down there. At first, I was like 'whatever', then I realized the true danger and scared the crap out of my 8 year old son when I started appreciating the full implications of my problem. I got the screw back, my son is still recovering. i have a dirty big bath towel i have always put down there when doing anything that could involve losing a bolt or anything else. i have several telescoping magnets that are very strong. fished out many a bolt on many a car with those. working on a citroen with a prv or later V6 is worse than anything a vw or porsche can dish up in terms of disappearing screws. they have numerous ledges, hydraulic lines and undertrays. you aint going to forget to take a dirty big bath towel out after you finish working either. even prevents the random rag incidents? |
Lo-Fi Version | Time is now: 17th May 2024 - 08:11 PM |
