FS: Miscellaneous parts |
partwerks |
Sep 2 2021, 07:50 PM
Senior Member Group: Members Posts: 1,593 Joined: 7-September 06 From: Grand Island, NE Member No.: 6,787 |
For sale: miscellaneous parts.
Paypal Friends and Family Option, or cash for local pickup. Asking price + shipping. All used parts, except for valve cover gaskets, and rear sway bar mounting brackets, and stiffener plates. 1. Steering shaft bellow/boot-$17.00 2. Lower rear trunk latch-$10.00-Sold 3. Upper rear trunk latch-Sold A. One with spring & no bushing-$15.00-Sold B. One without spring & no bushing-$10.00-Sold 4. Two lower front trunk latch A. Missing the cable clip and screw-$20.00 B. Complete with cable clip and screw-$24.00 5. Upper front trunk latch--$14.00 6. Door striker plates w/o guide-$3.00 each 7. LH pedal board hold down clamp-Two available-$3.00 each. RH side, round one-$2.00 (not pictured) 8. Two front tunnel covers-$3.00 each 9. Two door stays. A. Complete one-$6.00-Sold B. Other one has the roller missing-$4.00 10. Speedometer cable- in working order-has some crows feet cracks around (small) end of boot that pushes up on the firewall-$13.00 11. Two hood cable assemblies. Neither have the set screw that holds it in place under the dash. 1. One with plastic tube housing-$24.00 2. One without plastic tube housing-$20.00 12. DS engine lid grille section-$5.00-Sold 13. Fuel pump bracket-rubber isolators have some cracks in them. $20.00-Sold 14. DS & PS door latches-$40.00 for the pair-Sold 15. Air box mounting bracket-$24.00-sold. 16. Rear sway bar mounting brackets & support plates, w/o bolts-$48.00 17. Relay board cover bolt-$20.00 18. Battery hold down clamp-$3.00-sold 19. Spare tire bolt-$5.00-Sold 20. Engine lid grille latch with bolts-$23.00 21. Clutch pulley bracket with nut-$8.00 22. Front targa latches. $62.00 for all four. One pair is in decent condition. The other two are parts and repair to make one good one. One has a broken handle, and the other one, has a bent hook. 24. Pair of rear targa upper bumper receivers off of a 1974 top-One sold. One left-$23.00 25. Fuzzy strips. I think they are the inner ones? Seem like new-$4.00 each. 26. Two targa top centering wedges. One is missing one screw-$14.00 each. One with two screws is-Sold 27. Five lens retainer knobs-$5.00 28. Three sun visor mounts-$3.00 each-two sold, and one driver's side left. 29. Gas pedal adjustment stop bolt-$3.00 30. Two white targa top holders-hold the front edge of targe top in trunk-$4.00 each. 31. Roll bar latch surround (plastic) $3.00 32. Ski rack plastic plug-$2.00 Two available. 33. Trunk light-has a crack around one hole-$4.00 34. 35. Seat belt stop-$4.00 36. Triangle window cap-$2.00 37. Seat belt mount top cap-$3.00-Sold 38. Two rubber rear trunk targa top holder-Hold the rear of the targa top, in the trunk-$3.00 each-Sold 39. Brake fluid reservoir-has screen, but broken cap-$24.00 40. RH front side marker lens-prongs are broke-$13.00 41. Cigarette lighter housing-two in working order-$14.00 each. One sold, and one left. 42. Tripometer reset cables-one is missing the cap One with knob-$15.00-Sold One without the knob-$10.00 43.Emergency handbrake return spring-two available-$4.00 each-one is yellow plated. 44. Housing with rubber end. Was mounted in dash-$4.00 45. Valve cover gaskets-$7.00 46. Two black plastic pieces with two mounting holes, and a shark like fin sticking up? Were mounted under the dash-$4.00 47. Air deflectors-$10.00 48. Plastic elbows-one has over spray on it-$10.00 49. Rear targa latches-one has a piece of plastic broke off-otherwise in working order-$28.00-Sold. https://grandisland.craigslist.org/pts/d/gr...7396979458.html |
MM1 |
Sep 15 2021, 10:58 AM
914 obsession continues Group: Members Posts: 608 Joined: 9-May 18 From: Thousand Oaks, CA Member No.: 22,105 Region Association: Southern California |
9 and 9A for me please - sending PM now.
Lo-Fi Version | Time is now: 15th May 2024 - 01:20 PM |
