Lightweight doors |
Lightweight doors |
grantsfo |
Jul 25 2005, 08:26 PM
Arrrrhhhh! Group: Members Posts: 4,327 Joined: 16-March 03 Member No.: 433 Region Association: None |
Anyone have ideas on sources for lightweight 914 doors that would allow stock door handles and windows to work? How much weight can be saved by going from 1974 to earlier doors?
Randal |
Jul 25 2005, 08:29 PM
Bontempi probably has some.
SLITS |
Jul 25 2005, 09:10 PM
Have a couple of sets....you lose the impact bar only....don't know what it weighs.
eeyore |
Jul 25 2005, 09:18 PM
On my DOT approved, highly precise bathroom scales:
Stripped early door (nothing, nothing and nothing) - 25 lbs Complete late door (glass, inside panel, wing window, latches, etc) - 60 lbs Don't early doors have different window mechanisms? |
SLITS |
Jul 25 2005, 09:19 PM
Yep There are some early doors (late 72...Mid '73?) that have the late winder hardware but no impact bar, hence "lightweight racer" doors. |
olav |
Jul 25 2005, 09:20 PM
Senior Member Group: Retired Members Posts: 1,107 Joined: 28-December 02 From: Los Gatos, CA. USA Member No.: 34 Region Association: None |
I think a early door is 20lbs about and a late door is about 60lbs. I picked both up to gauge them. Quite a difference indeed. |
URY914 |
Jul 26 2005, 06:42 AM
I built the lightest 914 in the history of mankind. Group: Members Posts: 120,944 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
There is not that much differance in early vs late doors. I think this is a 914 myth. An COMPLETE early door weighs 45 pounds. I've weighed them myself.
There is a lot of differance between a stock complete late door and and a window-less early door. This is the weight savings route to take. Or go with a f/g door skin. Paul |
brant |
Jul 26 2005, 09:49 AM
914 Wizard Group: Members Posts: 11,632 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
If you want to keep the glass and keep it as a street car then I'm guessing your talking about 8-10 pounds max difference.
the door beam is a simple folded piece of sheet metal that is tacked in as a bar. Probably only weights 3 lbs for the bar itself. Still probably worth the switch for an autox car or something... The real weight savings is in removing the glass. I got my metal doors to 17lbs with working outside door handles (and modified inside ones) brant |
Aaron Cox |
Jul 26 2005, 09:52 AM
gut them and reskin them in AL or FG (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
Trekkor |
Jul 26 2005, 10:02 AM
Grant, I'm assuming you are keeping the glass is to stay in "FM", PCA class?
No glass moves you into "X" with the unlimited modifieds. In "X", anything goes. KT |
URY914 |
Jul 26 2005, 10:05 AM
I'm in triple X. Now were talking "anything" (IMG:http://www.914world.com/bbs2/html/emoticons/ohmy.gif) Some call it a obsession, others call it a hobby. I call it a fetish. (IMG:http://www.914world.com/bbs2/html/emoticons/unsure.gif) P |
Brett W |
Jul 26 2005, 10:40 AM
There is about a 20lb difference in the two doors. Early doors empty and late doors empty weight about 25 and 45 respectively.
Randal |
Jul 26 2005, 11:04 AM
From the PCA rule book: Glass: The car must have full windows (glass or Plexiglas).
Windows don't have to be glass. |
URY914 |
Jul 26 2005, 11:05 AM
I have both. I'll weigh them tonight. (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) |
Brett W |
Jul 26 2005, 11:10 AM
And I the same.
nebreitling |
Jul 26 2005, 11:15 AM
exactly. although plexiglass would be crazy -- why do they write that? you want polycarbonate, obviously. |
Randal |
Jul 26 2005, 11:22 AM
Available at TAP plastics |
URY914 |
Jul 26 2005, 11:24 AM
Use Surane Wrap.
redshift |
Jul 26 2005, 11:26 AM
I was going to ask if anyone had seen those snap-on canvas doors?
Camel looks great, on a black, or green car. M |
URY914 |
Jul 26 2005, 11:31 AM
Visqueen and duct tape.
Lo-Fi Version | Time is now: 31st May 2024 - 09:48 PM |
