Lightweight doors |
Lightweight doors |
Mueller |
Jul 26 2005, 11:33 AM
am I the only crazy person that has thought to have 2 sets of doors....1 "normal/safe" set for street and 1 extra-lite "race/auto-x" only doors??? of course a better/quicker method of R&R'ing them would make it easier........ |
neo914-6 |
Jul 26 2005, 12:22 PM
No I thought about it too since I have both sets (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) Quick release hinges (with needle bearings)! (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif) |
J P Stein |
Jul 26 2005, 12:39 PM
Complete late door......bathroom scale, 64lbs.
Totaly stripped (including inner panel) early door 20 lbs. |
URY914 |
Jul 26 2005, 12:47 PM
I built the lightest 914 in the history of mankind. Group: Members Posts: 120,944 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
URY914 |
Jul 26 2005, 06:46 PM
I weighed my collection of doors tonight.
They are as follows: This is a empty LATE door. Beam cut out, no handles, no glass, no nothing. 21 pounds. Attached thumbnail(s) |
URY914 |
Jul 26 2005, 06:48 PM
Late door WITH beam and latch. No handles, glass etc, etc.
39 pounds Attached thumbnail(s) |
URY914 |
Jul 26 2005, 06:51 PM
EARLY door with everything (including the inner panel and handles which were not on when this pic was taken)
45 pounds Attached thumbnail(s) |
URY914 |
Jul 26 2005, 06:55 PM
This means:
a. late door with all the pieces is pretty darn heavy. b. early door stripped out would be pretty darn light. c. I have four doors for sale. PM me. Paul |
SLITS |
Jul 26 2005, 07:00 PM
I assume these doors came from the highly touted 914 Limo (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif) |
grantsfo |
Jul 26 2005, 07:06 PM
Arrrrhhhh! Group: Members Posts: 4,327 Joined: 16-March 03 Member No.: 433 Region Association: None |
I just love the rule book. Especially when it comes to wheels in Fm. You have to reference two differnt sections to figure out that 8" wheels are legal with DOT rated R compound tires. I'll have to dig into the rule book. I'm prety handy with my grinder and my dremel. I'm thinking I could knock some weight out of the existing doors and keep them FM or GM legal. I was just thinking if there is a resource for reskined doors that will keep me in FM or GM classes I'd like to stay at that level of now. Seems like a good group of us are commited to FM ior new equivelent n Nor Cal so maybe I'll be a good boy and stay with class specs. |
Trekkor |
Jul 26 2005, 07:35 PM
Uh, guys...Look at page 23 of the 2005 Zone 7 PCA competition series code book.
Line item g) clearly states: "Glass: The car must have full glass ( no plexiglass windows ) ". Sorry to burst your bubble... (IMG:http://www.914world.com/bbs2/html/emoticons/sawzall-smiley.gif) KT |
Randal |
Jul 26 2005, 07:44 PM
It depends upon your your category within your class: If you're running Street Modified then you can use plexiglass as outlined below. And if that rule didn't apply then everyone running race tires would have to go back to 205's.
4.6 STREET MODIFIED CATEGORY Purpose: This is a category for highly modified cars that are still driven on the street. Basically anything goes. Batteries: Any battery may be used. Tires: Street tires: Any street tire/wheel combination may be used. Tires must be DOT approved. Race Tires: Race tires may be used, but may not be mounted on wheels wider than seven (7) inches or one inch wider than stock, whichever is greater. This leaves open the possibility of cars being competitive on very large street tires. Interior: The car must have full upholstery, carpeting and two seats. This keeps the category separate from the Modified Category. Fuel Tank Location: Fuel tanks/cells may be relocated, but not into the passenger compartment. Porsche: The chassis, engine and transmission must be Porsche. Glass: The car must have full windows (glass or Plexiglas). Electrical: Headlights, taillights, brake lights and turn signals must work. Induction System: Twin turbos may be used. Fuel mixture may be any injection or carburetion system. These changes are not permitted in the Production Category due to high costs. Engine Parts: Different cams may be used. Any brand pistons and cylinders are permitted. These changes are not permitted in the Production Category due to high costs. Gears, Ring & Pinion: Different gears and/or ring & pinion may be used. These changes are not permitted in the Production Category due to high costs, and to maintain the integrity of the classes. Tails, Wings, Airdams: Any tail, wing or airdam is permitted. The rear device may not obstruct rear vision. Brake Bias Valves: Any brake bias valve may be used. Suspension Struts: Any suspension strut may be used. Camber: Camber settings are free. Welding/Machining: Suspension modifications through welding or machining are permitted. Brakes: Any caliper and/or rotor may be used. |
URY914 |
Jul 26 2005, 07:45 PM
I stand corrected. I just weighed the door I made for Joe and it's 4 pounds. (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) |
Randal |
Jul 26 2005, 07:57 PM
FM is an Advanced Class for Street Modified Cars as outlined previously.
My Webpage Check out the web site, scroll down to "Advanced Classes." |
Brad Roberts |
Jul 26 2005, 08:01 PM
Last time I cut a door brace out, I *thought* it weighed close to 12lbs.
I read through everything posted and didnt see a door beam listed weighed out. B |
URY914 |
Jul 26 2005, 08:19 PM
Brad, you mean just the weight of the beam? I don't have the beam I cut out anymore, so I can't weigh it now. P |
Joe Ricard |
Jul 26 2005, 08:41 PM
Whoo Hooo! (IMG:http://www.914world.com/bbs2/html/emoticons/aktion035.gif) I just Love Street mod. it's perfect for a car tuner like me. Infact I just buttoned up my side shift transaxle tonight. Flipped 5th. new synchros and seals. I just can't wait to get that swapped out. |
Randal |
Jul 26 2005, 08:52 PM
Wasn't the purpose side impact, so it had to be beefy. |
brant |
Jul 27 2005, 09:14 AM
914 Wizard Group: Members Posts: 11,632 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
I'm sure my bathroom scale isn't perfectly calibrated...
but we put extra holes into the leading edge and into the hinges: Attached thumbnail(s) |
brant |
Jul 27 2005, 09:15 AM
We also took a sanding disc and cleaned off all of the spray on undercoater that is typically inside the door cavity. Then added extra holes to the bottom edge of the door.
came out to 17lbs according to my non scientific scale: Attached thumbnail(s) |
Lo-Fi Version | Time is now: 31st May 2024 - 11:05 PM |
