Sanity check, on the tunnel fuel lines |
mmichalik |
Sep 6 2021, 04:47 PM
MikeM Group: Members Posts: 697 Joined: 27-January 16 From: Valley Center, CA Member No.: 19,600 Region Association: Southern California |
I went to start changing out my fuel lines with a stainless steel set. When I pulled the tank out, the rubber lines basically feel apart.
I just took the rubber line off of the tunnel line when I noticed that the tunnel line was not plastic. It's what appears to be cadmium plated steel (my magnet stuck to it). Just as a sanity check, all 914's, particularly a 1974. came with plastic lines down the tunnel, correct? I believe the answer is yes. If that's the case, I can assume that the tunnel lines have been replaced in the past. They appear to be rust free and clean, should I continue with the Stainless replacement or just leave them there? |
Lo-Fi Version | Time is now: 17th May 2024 - 10:39 PM |
