Heat/Defrost Mixer Valve Removal, How does this come out ? |
jim_hoyland |
Sep 8 2021, 07:19 AM
Get that VIN ? Group: Members Posts: 9,270 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
How is that valve removed from under the cowling. My plan is to pull the gas tank for better access first; then replace the driver side heat/defrost valve. The re-install the control cables.
Any tips will be appreciated… ( see sample photo, not my car ) Attached image(s) |
DRPHIL914 |
Sep 15 2021, 12:11 PM
Dr. Phil Group: Members Posts: 5,764 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
How is that valve removed from under the cowling. My plan is to pull the gas tank for better access first; then replace the driver side heat/defrost valve. The re-install the control cables. Any tips will be appreciated… ( see sample photo, not my car ) Jim why are you pulling it out, for cleaning or replacing seals and cables? Phil |
jim_hoyland |
Sep 16 2021, 04:04 AM
How is that valve removed from under the cowling. My plan is to pull the gas tank for better access first; then replace the driver side heat/defrost valve. The re-install the control cables. Any tips will be appreciated… ( see sample photo, not my car ) Jim why are you pulling it out, for cleaning or replacing seals and cables? Phil I wasn’t able to get window defrost heat, only floor heat on the driver side. Removal of the valve showed the heat-side flapper was broken in half. How that happened ? No idea. |
Lo-Fi Version | Time is now: 3rd May 2024 - 05:40 AM |
