which fan pulley to use for 2.7L?, and various other engine questions |
Bob Wolcott |
Jul 25 2005, 10:57 PM
Member Group: Members Posts: 85 Joined: 18-May 05 From: McMinnville, OR Member No.: 4,096 |
I currently have two engines for my 914-6 and one has to go (original 2.0L) to finance the project. The 2.0 motor will be parted out and I have a few questions regarding which components to keep for the 2.7L motor.
For the fan assembly, I have one with a 3.25" pulley and another that is a bit larger (3.75"?) Which would be best to use on the 2.7? There will be a front mounted oil cooler. I have two alternators, the original and one that came with the 2.7L motor that is a bit different. Will they both work on a 914-6? Engine oil cooler: I have two oil coolers for this, the 914-6 original and one that came with the 2.7L. I know the 2.7L oil cooler would need to be modified for use on the -6 so is there any reason I couldn't use the original? Is there anything I am missing that I should keep or get rid of? Thanks, Bob |
Lo-Fi Version | Time is now: 31st May 2024 - 06:33 PM |
