CV joint help needed please, bearings out of position - fell out now what? |
DRPHIL914 |
Sep 13 2021, 03:20 PM
Dr. Phil Group: Members Posts: 5,766 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
so while installing the motor and transmission yesterday- and it seemed to go so smooth, the cv and axle got out of position, the inner must have gotten bumped and twisted , so i was just now trying to get the one that fell out back in , but also noticed they if i spin the axle the outer one is kind of off center as well, so now i am wondering if i am going to have to pull the whole axle to get these put back in the cage and on the axle?? seems like i will have to pull the whole assembly, to get them circlip off and put it all back together properly—-
pandora’s box here - opening a can of worms- i have to put it on the ground to take off the outer axle nut, then pull the shaft right? looks like there is not enough room to pull it with He in and that will have to be pulled too! - can i leave the other side all hooked up? Advice please!! Phil |
brant |
Sep 13 2021, 03:51 PM
914 Wizard Group: Members Posts: 11,623 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
yes....
and I have to loosen 2.... then take the brake off... spin the wheel 180... put the brake back on and finally loosen the last 2 |
DRPHIL914 |
Sep 13 2021, 04:29 PM
yes.... and I have to loosen 2.... then take the brake off... spin the wheel 180... put the brake back on and finally loosen the last 2 problem- it pulled out without the outer joint, those pins are in tight so the shaft came along with the bearings and inner cage- how am i going to pull this outer part off it? one step forward and 3 back Attached thumbnail(s) |
Lo-Fi Version | Time is now: 14th May 2024 - 08:46 PM |
