CV joint help needed please, bearings out of position - fell out now what? |
DRPHIL914 |
Sep 13 2021, 03:20 PM
Dr. Phil Group: Members Posts: 5,766 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
so while installing the motor and transmission yesterday- and it seemed to go so smooth, the cv and axle got out of position, the inner must have gotten bumped and twisted , so i was just now trying to get the one that fell out back in , but also noticed they if i spin the axle the outer one is kind of off center as well, so now i am wondering if i am going to have to pull the whole axle to get these put back in the cage and on the axle?? seems like i will have to pull the whole assembly, to get them circlip off and put it all back together properly—-
pandora’s box here - opening a can of worms- i have to put it on the ground to take off the outer axle nut, then pull the shaft right? looks like there is not enough room to pull it with He in and that will have to be pulled too! - can i leave the other side all hooked up? Advice please!! Phil |
iankarr |
Sep 13 2021, 05:07 PM
The wrencher formerly known as Cuddy_K Group: Members Posts: 2,473 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region |
Probably better at this point to just remove the castle nut and bang the stub axle out.
https://www.youtube.com/watch?v=7a5ACf2xK6Y&t=117s Please forgive the crude quality. I think it was the first 914 video I ever made. A 20Volt battery powered impact wrench will be your friend. And here's a video on how to refurbish the CV joints...made much more recently (IMG:style_emoticons/default/wink.gif) https://www.youtube.com/watch?v=F-5Xpug52Qw&t=277s |
Superhawk996 |
Sep 13 2021, 06:08 PM
914 Guru Group: Members Posts: 5,819 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
Probably better at this point to just remove the castle nut and bang the stub axle out. (IMG:style_emoticons/default/agree.gif) But I have access to an impact gun. However, theres is also minimal risk here is that you accidentally separate the rear wheel bearing races if the stub hasn't been out in 50 odd years and is likely to be stuck/corroded to the wheel bearing inner race. If you don't want to risk the wheel bearing, the other method suggested by Brant would be a really close 2nd for me. |
DRPHIL914 |
Sep 13 2021, 06:30 PM
Probably better at this point to just remove the castle nut and bang the stub axle out. (IMG:style_emoticons/default/agree.gif) But I have access to an impact gun. However, theres is also minimal risk here is that you accidentally separate the rear wheel bearing races if the stub hasn't been out in 50 odd years and is likely to be stuck/corroded to the wheel bearing inner race. If you don't want to risk the wheel bearing, the other method suggested by Brant would be a really close 2nd for me. i did all new bushings bearings and CV’s 6 years ago, along with the 5 lug conversion, all new bushings , pivot shaft etc etc. so everything including brake calipers and lines were put in new back then. it shouldn’t be rusted into place , but i see what you are saying about the bearing, i’d hate or damage that so hopefully the shat will slide out easily. so pissed i should have had the car running and doing the break in right now. i am telling you i have a freaking big pry bar 2 actually and tried working that back and forth and no feeling at all that those pins were working loose. |
Lo-Fi Version | Time is now: 15th May 2024 - 03:54 PM |
