CV joint help needed please, bearings out of position - fell out now what? |
DRPHIL914 |
Sep 13 2021, 03:20 PM
Dr. Phil Group: Members Posts: 5,766 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
so while installing the motor and transmission yesterday- and it seemed to go so smooth, the cv and axle got out of position, the inner must have gotten bumped and twisted , so i was just now trying to get the one that fell out back in , but also noticed they if i spin the axle the outer one is kind of off center as well, so now i am wondering if i am going to have to pull the whole axle to get these put back in the cage and on the axle?? seems like i will have to pull the whole assembly, to get them circlip off and put it all back together properly—-
pandora’s box here - opening a can of worms- i have to put it on the ground to take off the outer axle nut, then pull the shaft right? looks like there is not enough room to pull it with He in and that will have to be pulled too! - can i leave the other side all hooked up? Advice please!! Phil |
DRPHIL914 |
Sep 14 2021, 09:38 PM
PMB performance has CV joints but you have to enlarge 2 holes for the roll pins. I have a couple, one failed completely (with a cracked cage) and another has grooves deep enough to feel. These are precision bearings and must be inspected and assembled with tight tolerances. Scratching, galling any type of damage means the assembly is scrap. From what I can see Pelican has new assemblies, but cannot find anywhere else. After ordering CVs twice from Pelican, they do not fit 914-4 axles, no matter what their description says. The spline count in the center is wrong. (They were cool about refunds.) You've gone far enough to know you don't want to have to do this job again any time soon. Replace them. i looked at pelican, glad you said something about that . PMB performance, i saw that too, i don’t have time to get them and do all of thst right now, but inwould probably get the Tarett Engineering ones. this was not hard now thst i know i can pull that castle nut and slide it out thst easily it wouldn’t take long to pull both CV and replace them. budget it tight, it’ll have to wait. these were clean and should be fine for 6 months- a year. |
Lo-Fi Version | Time is now: 15th May 2024 - 10:45 AM |
