CV joint help needed please, bearings out of position - fell out now what? |
DRPHIL914 |
Sep 14 2021, 12:02 PM
Dr. Phil Group: Members Posts: 5,758 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
Phil - If you can see pitting or feel ridges with your fingernail, it's a problem. Discoloration usually isn't an issue. @mepstein Mark, yes its discoloration, i dont feel any ridges. i will take a closer look at the other end too once its off the stub, this was the inside one, at the transmission.. i just watched Ian karr's video and mine does not look like the one he shows with marks and grooves . Phil |
iankarr |
Sep 14 2021, 12:53 PM
The wrencher formerly known as Cuddy_K Group: Members Posts: 2,471 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region |
Arent' those pretty deep grooves in the last pic you posted?
930cabman |
Sep 14 2021, 01:40 PM
Advanced Member Group: Members Posts: 2,998 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States |
I have a couple, one failed completely (with a cracked cage) and another has grooves deep enough to feel. These are precision bearings and must be inspected and assembled with tight tolerances. Scratching, galling any type of damage means the assembly is scrap. From what I can see Pelican has new assemblies, but cannot find anywhere else.
Geezer914 |
Sep 14 2021, 05:45 PM
Geezer914 Group: Members Posts: 1,373 Joined: 18-March 09 From: Salem, NJ Member No.: 10,179 Region Association: North East States |
PMB performance has CV joints but you have to enlarge 2 holes for the roll pins.
bkrantz |
Sep 14 2021, 07:52 PM
914 Guru Group: Members Posts: 7,724 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains |
I have a couple, one failed completely (with a cracked cage) and another has grooves deep enough to feel. These are precision bearings and must be inspected and assembled with tight tolerances. Scratching, galling any type of damage means the assembly is scrap. From what I can see Pelican has new assemblies, but cannot find anywhere else. After ordering CVs twice from Pelican, they do not fit 914-4 axles, no matter what their description says. The spline count in the center is wrong. (They were cool about refunds.) |
rjames |
Sep 14 2021, 08:56 PM
I'm made of metal Group: Members Posts: 3,910 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
You've gone far enough to know you don't want to have to do this job again any time soon. Replace them.
DRPHIL914 |
Sep 14 2021, 09:33 PM
Arent' those pretty deep grooves in the last pic you posted? @iankarr no palpable grooves, discoloration only. similar to the side where you see coloration change but you can’t feel where that color change happens. it’s deceiving in the pictures. i know it’s tempting to replace them hard to find parts for rebuilding them, ans these were brand new 6 years ago and less than 10k miles. I had new boots , with just the 4 holes not 6, so i used those for this CV, all cleaned up and replaced new grease. I removed the castle nut, and easily pushed the stub out and man that stub axle was really stuck on that CV, pulled it all apart cleaned up and put new seals on, bolted back together , and is now in the car and mounted up. Your video was helpful! thanks! tomorrow i will be finishing the safety wiring on the CV bolts, and maybe get the HE back on the car, hook up the FI and wiring harness , if all goes well, break in could be Thursday. Did you do a video on setting rear venting clearance? this left side rotor and pad drags just a bit, i think while this wheel is off i need to do that. |
DRPHIL914 |
Sep 14 2021, 09:38 PM
PMB performance has CV joints but you have to enlarge 2 holes for the roll pins. I have a couple, one failed completely (with a cracked cage) and another has grooves deep enough to feel. These are precision bearings and must be inspected and assembled with tight tolerances. Scratching, galling any type of damage means the assembly is scrap. From what I can see Pelican has new assemblies, but cannot find anywhere else. After ordering CVs twice from Pelican, they do not fit 914-4 axles, no matter what their description says. The spline count in the center is wrong. (They were cool about refunds.) You've gone far enough to know you don't want to have to do this job again any time soon. Replace them. i looked at pelican, glad you said something about that . PMB performance, i saw that too, i don’t have time to get them and do all of thst right now, but inwould probably get the Tarett Engineering ones. this was not hard now thst i know i can pull that castle nut and slide it out thst easily it wouldn’t take long to pull both CV and replace them. budget it tight, it’ll have to wait. these were clean and should be fine for 6 months- a year. |
DRPHIL914 |
Sep 14 2021, 09:47 PM
tools for getting the castle nut off, and holding the hub in place , worth Ebrake on too, i used this heavy duty rebar water meter tool, worked great to hold it the T at end being placed on the ground , and the other end holds onto a lug the 2 lugs were covered with tape to prevent any damage to threads.
also i have a 30mm socket with this 2 gt breaker bar that i took the rubber handle off and sipped a piece of galvanized pipe over it to give a longer lever- easy peasy, then some light tapping on the axle end to push it back out of the trailing arm . Bearing looks fine- Attached thumbnail(s) |
DRPHIL914 |
Sep 14 2021, 09:51 PM
all done
Superhawk996 |
Sep 15 2021, 04:30 AM
914 Guru Group: Members Posts: 5,725 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
iankarr |
Sep 15 2021, 01:22 PM
Nice! Good work!
KELTY360 |
Sep 15 2021, 03:42 PM
914 Neferati Group: Members Posts: 5,028 Joined: 31-December 05 From: Pt. Townsend, WA Member No.: 5,344 Region Association: Pacific Northwest |
Happy ending!!…..well, at least a 914 happy ending. (IMG:style_emoticons/default/shades.gif)
Lo-Fi Version | Time is now: 19th April 2024 - 10:36 AM |
