The Crazy things we see on Craigslist |
JeffBowlsby |
Sep 13 2021, 04:21 PM
914 Wiring Harnesses Group: Members Posts: 8,477 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Think about this one for a moment, but not too long. I have a set of ramps just like this.
mb911 |
Sep 13 2021, 04:47 PM
914 Guru Group: Members Posts: 6,810 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
Hmm that had to fun to load backwards
raynekat |
Sep 13 2021, 05:03 PM
Advanced Member Group: Members Posts: 2,153 Joined: 30-December 14 From: Coeur d'Alene, Idaho Member No.: 18,263 Region Association: Pacific Northwest |
Or he just jacked the car up high enough to get the ramps underneath and didn't really think about which way they were pointing????
Jamie |
Sep 13 2021, 05:05 PM
Senior Member Group: Members Posts: 1,025 Joined: 13-October 04 From: Georgetown,KY Member No.: 2,939 Region Association: South East States |
Think about this one for a moment, but not too long. I have a set of ramps just like this. Must have jacked it up first, then placed the ramps. I used to have such ramps, scared myself attempting to drive on several times and gave them away! (IMG:style_emoticons/default/barf.gif) |
Sep 13 2021, 05:24 PM
914-6 GT in waiting Group: Members Posts: 19,238 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Or he just jacked the car up high enough to get the ramps underneath and didn't really think about which way they were pointing???? I’ve done that many times. I just use the ramp to keep the car off the ground. I usually point the ramps in opposite directions. I add in jack stands for - just in case. I tend to put a lot of stuff under the car if I can’t use a lift. |
wes |
Sep 13 2021, 07:39 PM
wes Group: Members Posts: 1,588 Joined: 8-December 07 From: Ukiah Ca Member No.: 8,436 Region Association: Northern California |
Or he just jacked the car up high enough to get the ramps underneath and didn't really think about which way they were pointing???? I’ve done that many times. I just use the ramp to keep the car off the ground. I usually point the ramps in opposite directions. I add in jack stands for - just in case. I tend to put a lot of stuff under the car if I can’t use a lift. I’ve done the same for jack stands plus it leaves room to slid in from the side. Ah but I’ve moved on to the Quick Jack. |
bkrantz |
Sep 13 2021, 07:50 PM
914 Guru Group: Members Posts: 7,732 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains |
Wait until he rolls off! (IMG:style_emoticons/default/screwy.gif)
(Full confession: I had ramps like that in black, and have fond memories of driving to drive up them while they slid across concrete screeching like crazy.) |
Front yard mechanic |
Sep 13 2021, 08:25 PM
Senior Member Group: Members Posts: 1,154 Joined: 23-July 15 From: New Mexico Member No.: 18,984 Region Association: None |
I have a set like those also but mine are rusted just like my car
Dustin |
Sep 13 2021, 09:02 PM
Member Group: Members Posts: 111 Joined: 19-August 10 From: Woodland Hills, CA Member No.: 12,072 Region Association: None |
I do this because if you drive up them the ramp is in a bad position for working under the car. Usually they're under the rear wheels though.
Montreal914 |
Sep 13 2021, 09:04 PM
Senior Member Group: Members Posts: 1,541 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California |
Placing the ramps like this gave him access for the floor jack to lift off of the underbody donuts? (IMG:style_emoticons/default/confused24.gif)
Steve |
Sep 13 2021, 10:05 PM
914 Guru Group: Members Posts: 5,569 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
I did the same thing back in the day…. Car was too low to the ground to drive up them, so I used them as jack stands with a floor jack. I eventually bought jack stands and threw them away.
JamesM |
Sep 14 2021, 12:07 AM
Senior Member Group: Members Posts: 1,888 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region |
Or he just jacked the car up high enough to get the ramps underneath and didn't really think about which way they were pointing???? I’ve done that many times. I just use the ramp to keep the car off the ground. I usually point the ramps in opposite directions. I add in jack stands for - just in case. I tend to put a lot of stuff under the car if I can’t use a lift. (IMG:style_emoticons/default/agree.gif) I do this all the time in place of jackstands. My ramps have a chock at the top to stop you from rolling over them so ill place one ramp forward and the other in the reverse direction the car from moving. A couple of my cars are so low they cant drive up the ramps anyways so jacking is mandatory. |
Spoke |
Sep 14 2021, 05:41 AM
Jerry Group: Members Posts: 6,973 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
Or he just jacked the car up high enough to get the ramps underneath and didn't really think about which way they were pointing???? I've done this many times. First off, I don't like driving my car up the ramp. I'm always afraid I'll gun the motor too much and go right off of them. Second the ramp part gets in the way if I need to get under the car on that side. |
jd74914 |
Sep 14 2021, 07:14 AM
Its alive Group: Members Posts: 4,776 Joined: 16-February 04 From: CT Member No.: 1,659 Region Association: North East States |
I like to put ramps in opposing directions so there is a reduced chance of the car rolling off.
VaccaRabite |
Sep 15 2021, 12:04 PM
En Garde! Group: Admin Posts: 13,423 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
I used to do this too. Jack the car up and put it on ramps with the ramps pointed the wrong way. Made it a lot easier to get under the car. I've also placed them so the ramps faced 90 degrees away from the car. Putting the front end of the car on ramps made taking the engine out a little easier since it was not at such a steep angle once you had the back end high enough to get clearance for the engine and the jack (21 inches from valence to concrete IIRC).
Zach |
LefthandRev |
Sep 16 2021, 10:26 AM
Member Group: Members Posts: 71 Joined: 9-August 21 From: Seattle, WA Member No.: 25,787 Region Association: Pacific Northwest |
Or he just jacked the car up high enough to get the ramps underneath and didn't really think about which way they were pointing???? I've done this many times. First off, I don't like driving my car up the ramp. I'm always afraid I'll gun the motor too much and go right off of them. Second the ramp part gets in the way if I need to get under the car on that side. I've run off them in my '70 Monte Carlo and my '88 Land Cruiser. This is a valid concern. |
Chris914n6 |
Sep 16 2021, 05:45 PM
Jackstands are my life. Group: Members Posts: 3,304 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
I use ramps as stands often as they are way more stable on my driveway. I think in this pic I was preparing to swap the trans and got sidetracked with wheels (IMG:style_emoticons/default/idea.gif)
(IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-431-1631835910.1.jpg) |
ndfrigi |
Sep 16 2021, 05:55 PM
I did the same thing back in the day…. Car was too low to the ground to drive up them, so I used them as jack stands with a floor jack. I eventually bought jack stands and threw them away. same here and still have those type of ramp. Using it for safety instead of jack stand. This week I was planning to leave it outside the garage if someone wants it. Or maybe metal truck guy will see it. |
Lo-Fi Version | Time is now: 25th April 2024 - 05:34 AM |
