where to find a 50mm wheel stud?, did I measure at the correct place ?... I believe this is 45mm |
brant |
Sep 15 2021, 08:44 AM
914 Wizard Group: Members Posts: 11,618 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
anyone know a competitive priced place to find a 50mm wheel stud?
I had a tire rub on the inside during my trip to RRC threw spacers on (5mm) so looking at my options for this problem one of which is to put in a longer stud Attached image(s) |
mepstein |
Sep 15 2021, 09:13 AM
914-6 GT in waiting Group: Members Posts: 19,254 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
I believe summit racing has a good selection
brant |
Sep 15 2021, 09:26 AM
Spoke |
Sep 15 2021, 10:52 AM
Jerry Group: Members Posts: 6,978 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
Eric Shea pointed me to these guys a while back. Their link is not working now. Not sure what that means.
www.race-studs.com |
brant |
Sep 15 2021, 11:02 AM
Eric Shea pointed me to these guys a while back. Their link is not working now. Not sure what that means. www.race-studs.com thanks... I'll keep checking on them. going to see how much I can grind away from the inner GT-stiffening plate the rub is only pretty much happening on one of the proud welds.. so might be able to partially solve my problem with the grinder... and see how much good that does. brant |
Chris914n6 |
Sep 15 2021, 08:41 PM
Jackstands are my life. Group: Members Posts: 3,307 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
You will likely need to get a Porsche stud from a Porsche place.
You might not need longer studs, 5mm isn't that much. I ran 5/16" spacers for years. Then I scored 65mm studs from a 944 rear at the PaP and went to 21mm spacers. Also Ebay has 3mm (1/8") spacers if you just need a bit. |
Lo-Fi Version | Time is now: 3rd May 2024 - 07:50 AM |
