> Best 914-6 engine mount
David Stowers
post Sep 15 2021, 10:53 AM
Hi Guys
I need to choose an engine mount for my conversion. Any pros and cons of which type to go for?
I understand height on install is an issue to get a good air seal to avoid overheating issues
Thanks
lesorubcheek
post Sep 16 2021, 08:24 AM
One issue to consider is the brake pressure regulator. It's been mentioned that cars with the later setup likely have to relocate the regulator farther toward the driver's side so it has proper clearance with the /6 mount. Looks like in the PET the change was made in the '74 model year after VIN 4742915751. Do all styles of the /6 mounts have this issue? Pretty sure I've read posts where the OEM style mount has the problem. Just looking, I'd guess the Bulkhead mount would also, but can't be sure.
Dan
Luke M
post Sep 16 2021, 12:09 PM
QUOTE(lesorubcheek @ Sep 16 2021, 07:24 AM) *
Dan
I just went through this with my brothers 914. He has a 74 with the RJ 6 conversion mount welded in place. Yes, the pressure regulator needs to be relocated or swapped out for a T fitting. You also need new brake lines bent to fit properly. We went with the T fitting. The brakes he is using are PMB converted GT 6 calipers in the rear, and 911 Aluminum S calipers up front.
If I where to do another 6 conv I would use the OEM style Maddog mount setup which is a copy of the factory 6 mount.
David Stowers   Best 914-6 engine mount   Sep 15 2021, 10:53 AM
nditiz1   Hi Guys I need to choose an engine mount for my c...   Sep 15 2021, 10:54 AM
930cabman   Hi Guys I need to choose an engine mount for my ...   Sep 15 2021, 06:10 PM
dr914@autoatlanta.com   The best buy for the smaller engines through 2.4 i...   Sep 15 2021, 11:02 AM
David Stowers   The best buy for the smaller engines through 2.4 ...   Sep 15 2021, 11:24 AM
Steve   The best buy for the smaller engines through 2.4...   Sep 15 2021, 11:44 AM
brant   the PMS tilting mount has the advantage of easier ...   Sep 15 2021, 11:12 AM
Justinp71   the PMS tilting mount has the advantage of easier...   Sep 15 2021, 11:21 AM
brant   the PMS tilting mount has the advantage of easie...   Sep 15 2021, 12:28 PM
Steve   [quote name='Justinp71' post='2945711' date='Sep ...   Sep 15 2021, 01:29 PM
Justinp71   [quote name='Justinp71' post='2945711' date='Sep ...   Sep 15 2021, 05:57 PM
Tdskip   The Naro mount is easy to install and everything f...   Sep 16 2021, 06:09 AM
ClayPerrine   I have had the Rich Johnson mount. While it is a ...   Sep 16 2021, 06:12 AM
lesorubcheek   One issue to consider is the brake pressure regula...   Sep 16 2021, 08:24 AM
Steve   One issue to consider is the brake pressure regul...   Sep 16 2021, 09:04 AM
ClayPerrine   One issue to consider is the brake pressure regul...   Sep 16 2021, 09:29 AM
Steve   One issue to consider is the brake pressure regu...   Sep 16 2021, 10:26 AM
Luke M   One issue to consider is the brake pressure regul...   Sep 16 2021, 12:09 PM
Mark Henry   One issue to consider is the brake pressure regul...   Dec 16 2021, 06:42 PM
lesorubcheek   You won't be sorry and Dave is easily availab...   Dec 16 2021, 08:27 PM
SKL1   If using the maddog mount, do people recommend the...   Sep 16 2021, 12:55 PM
lesorubcheek   First, David, thanks for starting this thread and ...   Sep 16 2021, 01:26 PM
Superhawk996   From an NVH standpoint, the URO OEM style mount is...   Sep 16 2021, 02:07 PM
lesorubcheek   What really makes the OEM style mount superior to ...   Sep 17 2021, 11:09 AM
mb911   What really makes the OEM style mount superior to...   Sep 17 2021, 12:27 PM
Steve   What really makes the OEM style mount superior to...   Sep 17 2021, 12:31 PM
ClayPerrine   I always wondered why Porsche didn't add the p...   Sep 17 2021, 01:55 PM
mb911   I always wondered why Porsche didn't add the ...   Sep 17 2021, 02:41 PM
Steve   I always wondered why Porsche didn't add the...   Sep 17 2021, 02:47 PM
mepstein   [quote name='mb911' post='2946255' date='Sep 17 2...   Sep 17 2021, 03:19 PM
burton73   Factory engine mount stiffening modification. Inst...   Sep 17 2021, 03:41 PM
burton73   For reference of mount with it put on a painting r...   Sep 17 2021, 04:44 PM
lesorubcheek   This is amazing information. Here's a few thin...   Sep 17 2021, 06:07 PM
lesorubcheek   After much deliberation, finally pulled the trigge...   Dec 16 2021, 02:05 PM
930cabman   After much deliberation, finally pulled the trigg...   Dec 16 2021, 03:09 PM
rgalla9146   After much deliberation, finally pulled the trigg...   Dec 16 2021, 08:06 PM
- Lo-Fi Version Time is now: 9th May 2024 - 08:04 PM
