Best 914-6 engine mount |
David Stowers |
Sep 15 2021, 10:53 AM
Member Group: Members Posts: 99 Joined: 28-June 12 From: UK Member No.: 14,613 Region Association: None |
Hi Guys
I need to choose an engine mount for my conversion. Any pros and cons of which type to go for? I understand height on install is an issue to get a good air seal to avoid overheating issues Thanks |
lesorubcheek |
Sep 16 2021, 08:24 AM
Member Group: Members Posts: 193 Joined: 21-April 21 From: Florida Member No.: 25,463 Region Association: South East States |
One issue to consider is the brake pressure regulator. It's been mentioned that cars with the later setup likely have to relocate the regulator farther toward the driver's side so it has proper clearance with the /6 mount. Looks like in the PET the change was made in the '74 model year after VIN 4742915751. Do all styles of the /6 mounts have this issue? Pretty sure I've read posts where the OEM style mount has the problem. Just looking, I'd guess the Bulkhead mount would also, but can't be sure.
Dan |
Mark Henry |
Dec 16 2021, 06:42 PM
One issue to consider is the brake pressure regulator. It's been mentioned that cars with the later setup likely have to relocate the regulator farther toward the driver's side so it has proper clearance with the /6 mount. Looks like in the PET the change was made in the '74 model year after VIN 4742915751. Do all styles of the /6 mounts have this issue? Pretty sure I've read posts where the OEM style mount has the problem. Just looking, I'd guess the Bulkhead mount would also, but can't be sure. Dan I made a copy of a copy of a RJ mount, for the brake pressure regulator I just cut out the whole side gusset area of interference, then I welded a new HD shaped gusset. Except for a creative brake line path mine bolts up like stock. |
lesorubcheek |
Dec 16 2021, 08:27 PM
You won't be sorry and Dave is easily available for support. Keep us posted as you continue down the /6 conversion road Sure will. It's a slow start though. Still in the planning and acquisition phase. Development won't begin until at least another year and that's if I'm lucky. I made a copy of a copy of a RJ mount, for the brake pressure regulator I just cut out the whole side gusset area of interference, then I welded a new HD shaped gusset. Except for a creative brake line path mine bolts up like stock. Smart way to handle it. Ours was built in late '73 and looks like it won't have the problem of relocating . You made the right choice. It is as close to original as you can get.... so no compromises. When installing the engine be sure to have a 16" drift pin on hand to guide the front engine mount up toward the body mount..... the rear mounts will then go right where they belong. Before these were available I fabricated a copy of the body mount for my GT conversion because the others available all had one or more issues. No regrets. Really pleased with how it's put together. Thanks for the suggestion, makes perfect sense. It's this kind of detail that can make all the difference when it comes times to do the install. Dan |
Lo-Fi Version | Time is now: 10th May 2024 - 01:42 AM |
