Strong Fuel Smell, Is it normal... |
Rick986 |
Sep 15 2021, 01:27 PM
0-60 in 14 seconds! Group: Members Posts: 141 Joined: 31-August 21 From: NE Ohio Member No.: 25,869 Region Association: Upper MidWest |
...to be getting a fairly strong fuel smell in the frunk? I can smell it pretty good in the garage. Having the car inspected Friday but just wondering if this is typical. Thanks!
r_towle |
Sep 15 2021, 06:10 PM
Custom Member Group: Members Posts: 24,574 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
I would do it so you know they are new and they are the correct type of hose for the ethanol fuel.
It has been done wrong before, and ethanol eats away at the rubber. If not that, there is a charcoal venting system, which after 40 years has served its full life span. You can replace the charcoal, google that. I doubt you can buy a new canister fir a 914. I would start with easiest, work your way up 1) gas cap gasket 2) rubber fuel lines 3) canister 4) pull the tank out and find the leak Meanwhile either park it outside or open a window in the garage. |
Lo-Fi Version | Time is now: 17th May 2024 - 11:11 PM |
