Chokes the same on Weber 32/36 DFEV vs. DGEV? |
Chaznaster |
Sep 15 2021, 07:44 PM
Member Group: Members Posts: 284 Joined: 22-November 15 From: Concord, MA Member No.: 19,389 Region Association: North East States |
Hi.
Does anyone here know if the electric choke modules are interchangeable between the Weber DGEV and DFEV 32/62’s? I have been scouring the internet for this topic without any clear conclusion. Thanks much! |
JamesM |
Sep 15 2021, 08:28 PM
Senior Member Group: Members Posts: 1,875 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region |
IDK but you could compare the individual part numbers and see.
https://www.carbparts.eu/exploded_view/WEBER_32-36_DFAV-DFEV https://www.carbparts.eu/exploded_view/WEBER_32-36_DGAV-DGEV |
Chaznaster |
Sep 16 2021, 04:36 PM
Thanks JamesM. I appreciate the links. I am still reasonably new to this and not savvy about finding parts lists, etc. It looks like the are different: x.332 for the DF series and x.333 for the DG. Probably mirror images like the carbs are.
porschetub |
Sep 16 2021, 08:24 PM
Advanced Member Group: Members Posts: 4,695 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Thanks JamesM. I appreciate the links. I am still reasonably new to this and not savvy about finding parts lists, etc. It looks like the are different: x.332 for the DF series and x.333 for the DG. Probably mirror images like the carbs are. Should fit both carbs ,do you really need it? these take careful setting otherwise they stay on too long and fuel wash your engine,if they stay on all the time they will destroy your engine rather quickly,fuel is a crappy lubricate. These carbs are based on motors that used a coolant water feed choke (bymetal )and that worked fine till you had a bad thermostat or coolant leaks. Unless you live in a very cold year round climate don't bother,3-4 pumps on the throttle and a short warm should be fine with the choke set fully open. Good luck. |
Lo-Fi Version | Time is now: 29th March 2024 - 08:25 AM |
