FS: Rebuilt Pedal Cluster |
DLewis |
Sep 16 2021, 05:41 PM
Member Group: Members Posts: 63 Joined: 3-December 04 From: Poway, CA (was SF Bay area) Member No.: 3,212 Region Association: None |
For sale a rebuilt pedal cluster. It is from a 914 but can be used for a 911 68-73. I have both clutch arms (straight for a 911 vs. bent in a 914).
Sanded and wire wheeled. Primed all the black pats then on two coats of Rustoleum Semi-gloss black. Did not have to do anything to the other parts. All new springs, bronze bushings, and rubber stops. These are getting harder and harder to rebuild but this one is perfect. Works very smooth. Base has virtually no pitting. Actually the whole cluster was very rust free to begin with. Roll pin came out and clutch arm came off pretty easy. You will have to use your brake switch. $320 shipped in the US. Others, we can discuss. If you want to send me your old one I will give you $75 off (you pay shipping) if it isn't too bad, you decide. Thanks, Dean |
DLewis |
Mar 20 2023, 06:49 PM
Got one done.
I have both arms for the clutch, so it can be for a LWB 911/912 or a 914. Sanded and wire wheeled. Primed all the black parts then on two coats of Eastwood Extreme chassis satin black. Did not have to do anything to the other parts. All new springs, bronze bushings, and rubber stops. Works very smooth. Base has NO pitting on the inside or outside. Very smooth, best one I have seen in a long time. Actually the whole cluster was very rust free to begin with. Roll pin came out and clutch arm came off pretty easy. You will have to use your brake switch. $350 shipped in the US. Others, we can discuss. If you want to send me your old one I will give you $75 off (you pay shipping) if it isn't too bad, you decide. Thanks, Dean |
Lo-Fi Version | Time is now: 17th May 2024 - 02:47 PM |
