alternatives to, engine tin |
ArtechnikA |
Jul 26 2005, 02:28 PM
and then there's the guy who uses the gasoline-powered fan to cool his electric 914 :-) ...
brant |
Jul 26 2005, 02:29 PM
914 Wizard Group: Members Posts: 11,632 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
It works.. someone will probably chime in, but I've never heard of a single head problem I did it for a year or two and know of a dozen other people that have done it also.... one ancedotal would be that you don't hear of cracked heads everytime it rains..... It works good for about 15 minutes brant |
Mueller |
Jul 26 2005, 02:31 PM
a few decent threads on this cooling method (with numbers) on the pelican site......I wouldn't worry about thermal shock unless you dumped a 5 gallon bucket of water on the heads all at once while at max. operating temp.... |
brant |
Jul 26 2005, 02:33 PM
regarding the electric fan Idea.
I should have gotten pictures. all of the AJRS cars run a 16 or so inch electric fan straight down onto the motors.. usually they have a 2nd small battery that runs in total loss mode for this fan. This has been an AJRS standard for about 8 years now. He runs them on the -6 motors too. In fact a week ago at an event one of the fastest cars he has ever built had one on the 3.3 twin plug, electromotive, high compression motor (probably a 350hp engine) He also ducts a roof naca into the engine bay, so your getting some good ram air cooling too. and none of his cars run engine tin in race trim. In fact when I was there on saturday he was showing me a dyno sheet on a PCA GT class 912. It runs a type IV motor with 195hp and 180ft/lbs at the wheels (@5000 foot of altitude) so its definitely doable, but its really a race only setup. brant |
Cap'n Krusty |
Jul 26 2005, 04:14 PM
Well, jeeezzzz, you're no fun. You're SUPPOSED to argue with us and insist you're gonna go ahead anyway................................... The Cap'n, who has seen with hisveryowneyes the results of running an aircooled motor with no tin .................. |
bd1308 |
Jul 26 2005, 05:32 PM
warp the heads. blow a hole in the side of the case. Take pictures.
sean_v8_914 |
Jul 26 2005, 10:06 PM
are you guys asleep? teh wind mills could be mounted to teh roof.
Dr Porsche already did a car with electric motor driven front hubs...in 1910. the batteries weighed in at a trim 5000 lbs |
bd1308 |
Jul 26 2005, 10:08 PM
i have pictures of that very car. cool indeed. I have a history of porsche book.
Lo-Fi Version | Time is now: 31st May 2024 - 10:11 PM |
