914 Fuel Expansion Tank?, In Tank Fuel Pump |
Conceivedready61 |
Sep 19 2021, 01:49 PM
Newbie Group: Members Posts: 12 Joined: 23-July 18 From: Oregon Member No.: 22,334 Region Association: None |
Hello All: Not sure if this question has been addresses here as I couldn't find it, But,,,, I'm doing a V8 conversion in my 914 with a late model GM L83 aluminum block that has direct injection. I have purchased an in tank pump( Holley Sniper) to supply the direct injection pump on the engine. This is a non return type system, although the pump has ports for Return and a Vent, the return is plugged in this scenario. My question is with this do I need to keep the Yugly Fuel expansion tank?? Also where does the Vent go from the intank pump?
Thanks in advance for any help..... |
FL000 |
Sep 21 2021, 08:45 PM
Member Group: Members Posts: 389 Joined: 31-January 12 From: Lancaster, CA Member No.: 14,076 Region Association: Southern California |
I recommend keeping as much of the expansion tank / charcoal setup as possible. I have a similar setup as you but have the fuel return also. I ditched the expansion tank but preserved the charcoal canister. I route a hose exiting the canister to my air cleaner.
If I fill the tank up to the brim I get a slight smell of gas the first few miles which I can live with. Without the canister there is a more persistent smell. Maybe better ways to do it but works for me. |
Lo-Fi Version | Time is now: 26th April 2024 - 08:20 PM |
