Curious what you all think of this dyno read out? |
Tdskip |
Sep 20 2021, 01:02 PM
Advanced Member Group: Members Posts: 3,686 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None |
Several twists and turns I’m getting close to getting that XN turbo big bore engine back to me. This is the one that had a very elaborate homebrew turbo set up turns out was only running on three out of four cylinders when I did the initial teardown. I ended up having to swap the case out for another one because when it was rebuilt for the first time it was developing crazy high will pressure hand given all the unknowns and some funkiness with it that we discovered we decided it would be better to just use another case
Shop let me know going in the carbs I gave them would be snappy and responsive but probably leave horsepower on the table. The shop also noted that this was not run using optimized headers and exhaust is probably a bit restrictive for this sort of build. Thing that really jumps out to me here is that the engine is making lotta torch, or at least seems to be a lot of work, down low and had a very usable or p.m. That, to my son white uneducated eyes, suggest that should be fun for regular street use. What do you all think? |
Rufus |
Oct 1 2021, 06:11 PM
Member Group: Members Posts: 314 Joined: 8-April 06 From: Central NC Member No.: 5,840 Region Association: None |
Agree with the others. Something’s fishy about the torque and power readings not being equal (the curves should cross) at 5252 rpm assuming torque is measured in lb-ft and power in hp and they’re numerically on the same scale.
JMHO, but I wouldn’t use the curves, or pay for the dyno testing until presented with data that makes sense. These curves don’t. FWIW: this’s the 1st thing I look at as most of my career involved engine performance / emissions development & testing. |
Lo-Fi Version | Time is now: 17th May 2024 - 09:04 AM |
