Temperature Gauge Jumping, Is there a "quick fix"? |
Rick986 |
Sep 21 2021, 02:38 PM
0-60 in 14 seconds! Group: Members Posts: 141 Joined: 31-August 21 From: NE Ohio Member No.: 25,869 Region Association: Upper MidWest |
My console temp gauge either bounces all over the place or just stays in the red (even on a cold engine). Has anybody had this specific issue they sorted out previously? Thanks.
dr914@autoatlanta.com |
Sep 21 2021, 02:39 PM
914 Guru Group: Members Posts: 7,772 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
loose wire between the main harness and the sending unit underneath the engine
914Sixer |
Sep 22 2021, 01:10 PM
914 Guru Group: Members Posts: 8,845 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Sending wire is going open. Replace wire from sender to plug under battery with temporary wire. See if problem goes away.
Rick986 |
Sep 22 2021, 05:00 PM
loose wire between the main harness and the sending unit underneath the engine Hey George - where exactly is that "sending unit"? (your Tech Tips book is on its way!) And did the other respondent essentially say the same thing? Is that "main harness" by the battery? Thanks! - Rick |
emerygt350 |
Sep 22 2021, 05:03 PM
Advanced Member Group: Members Posts: 2,025 Joined: 20-July 21 From: Upstate, NY Member No.: 25,740 Region Association: North East States |
Right down by the drain plug and strainer.
914Sixer |
Sep 22 2021, 05:05 PM
Look on the bottom of engine. You can see where wire is. Wire plug in is under battery tray on engine shelf from main harness.
Rick986 |
Sep 23 2021, 11:42 AM
Thanks guys!
LefthandRev |
Sep 23 2021, 11:50 AM
Member Group: Members Posts: 62 Joined: 9-August 21 From: Issaquah, WA Member No.: 25,787 Region Association: Pacific Northwest |
Crazy. We're working on the same thing at the same time. Not sure how I didn't notice this before posting.
Rick986 |
Sep 28 2021, 09:06 AM
Lo-Fi Version | Time is now: 29th March 2024 - 07:56 AM |
