hmmm, side window to seal issue with targa off |
bd1308 |
Jul 26 2005, 09:32 AM
with the top on, everything works great on the driver side...IE window rolls up down and follows the track. With the top off, the window does not follow the track...it tends to want to go on the inside of the side window seal...is this a sign of my longs finally giving out or is this a common occurance?
redshift |
Jul 26 2005, 09:40 AM
While you are driving? I don't think it has anything to do with your longitudinals..
M |
scotty914 |
Jul 26 2005, 09:45 AM
suby torque rules Group: Members Posts: 1,525 Joined: 20-July 03 From: maryland, the land of 25 year Member No.: 924 |
i would look the adjusment for the window, the front might be getting pushed out enough for the window to run in the right place
bd1308 |
Jul 26 2005, 09:48 AM
okay....that's a relief.
yeah it was while i was driving where does one get OsPho? not at FLAPS. |
Allan |
Jul 26 2005, 10:02 AM
Home Depot, Lowe's, local auto paint supplier, etc................ |
bd1308 |
Jul 26 2005, 10:19 AM
SGB |
Jul 27 2005, 09:51 AM
If I'm running about 80, my windows bind about 2/3rds up being pushed in by the wind.
Joe Ricard |
Jul 27 2005, 10:06 AM
I stumbled upon a fix for mine. 1st I did the long rebuild thing. put doors back on and still had funky window fitment.
I realized that the actual windshield had laid back a smidge of a degree. Pushing on the side window guides. So with the top off I took a deep breath and backed my butt up to the top of the winshield frame. Did a kind of squat push and pushed the windshield froward and up. Don't do this too hard the frame IS NOT AS STRONG AS YOU MIGHT THINK. Actually it's pretty whimpy. Windows fit great now. Last words BE CAREFUL |
bd1308 |
Jul 27 2005, 10:28 AM
thanks joe. Makes sense, i could see that happening.
Jul 27 2005, 11:13 AM
Resident German Group: Admin Posts: 41,674 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
the window (including the channels) can be adjusted as can the seals. for the seals, remove rubber part then move the aluminum channles around. for the windows, there are adjustement screws on the bottom of the door as well as inside the door. the whole assembly (including the triangle window) can be moved any way you want ... (IMG:http://www.914world.com/bbs2/html/emoticons/smash.gif) Andy |
bd1308 |
Jul 27 2005, 11:16 AM
i wish the triangle windows could be remade to swivel, to act as a windfoil?
redshift |
Jul 27 2005, 11:58 AM
Lo-Fi Version | Time is now: 5th June 2024 - 07:32 PM |
