Screaming engine |
Screaming engine |
TonyA |
Sep 25 2021, 09:16 AM
Nachmal Group: Members Posts: 470 Joined: 17-November 16 From: Hilltown PA Member No.: 20,596 Region Association: North East States |
Here are the symptoms. 2.0 engine running duel Webber’s no chokes. Tried to go to C&C this morning a really cold 45 would not start so I sprayed a little starting fluid into carbs it fired a little because I really want my coffee. Sprayed a little more it fired up and screamed to 5-6K Rpm. Had to turn the key off. Let is sit a little while fired it up again and again screaming to 5-6K. Throttles not stuck. Started again and it idled nicely. Without touching the gas pedal it screams again to 6K. My only thoughts are the new fuel pump that I installed back in July which ran great all summer may be the cause. Any other suggestions. Help I need to get my coffee.
TonyA |
Sep 25 2021, 12:43 PM
Thanks guys. Gaskets all look good from the outside I did not disassemble yet. Everything was fine when I parked it two weeks ago. So if there is a vacuum leak somewhere it is still getting way to much fuel and it would still be a faulty pump correct? It did idle at one point and then ran wild so how could that happen if there was a vacuum leak that suddenly closed up. The pump sounds like it does not stop like the fuel injector type. Is this normal on the carb fuel pumps? Not sure where I purchased it.
Lo-Fi Version | Time is now: 21st May 2024 - 01:27 PM |
