Screaming engine |
Screaming engine |
TonyA |
Sep 25 2021, 09:16 AM
Nachmal Group: Members Posts: 470 Joined: 17-November 16 From: Hilltown PA Member No.: 20,596 Region Association: North East States |
Here are the symptoms. 2.0 engine running duel Webber’s no chokes. Tried to go to C&C this morning a really cold 45 would not start so I sprayed a little starting fluid into carbs it fired a little because I really want my coffee. Sprayed a little more it fired up and screamed to 5-6K Rpm. Had to turn the key off. Let is sit a little while fired it up again and again screaming to 5-6K. Throttles not stuck. Started again and it idled nicely. Without touching the gas pedal it screams again to 6K. My only thoughts are the new fuel pump that I installed back in July which ran great all summer may be the cause. Any other suggestions. Help I need to get my coffee.
Spoke |
Sep 25 2021, 08:21 PM
Jerry Group: Members Posts: 6,983 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
Something doesn't sound right with this issue. First off, if there is a vacuum leak with carbs, the engine will run lean and not run well. Plus since it has dual carbs, it is unlikely that both sides would develop a vacuum leak at the same time.
As previously mentioned, if there is an high fuel pressure issue the engine would run very rich and not well at all. I think I'm on board with the thought that the butterflies are hanging up. |
Lo-Fi Version | Time is now: 21st May 2024 - 04:49 AM |
