Screaming engine |
Screaming engine |
TonyA |
Sep 25 2021, 09:16 AM
Nachmal Group: Members Posts: 470 Joined: 17-November 16 From: Hilltown PA Member No.: 20,596 Region Association: North East States |
Here are the symptoms. 2.0 engine running duel Webber’s no chokes. Tried to go to C&C this morning a really cold 45 would not start so I sprayed a little starting fluid into carbs it fired a little because I really want my coffee. Sprayed a little more it fired up and screamed to 5-6K Rpm. Had to turn the key off. Let is sit a little while fired it up again and again screaming to 5-6K. Throttles not stuck. Started again and it idled nicely. Without touching the gas pedal it screams again to 6K. My only thoughts are the new fuel pump that I installed back in July which ran great all summer may be the cause. Any other suggestions. Help I need to get my coffee.
slivel |
Sep 27 2021, 01:31 PM
Old car....... older driver Group: Members Posts: 509 Joined: 10-July 04 From: San Diego Member No.: 2,332 Region Association: Southern California |
+1 on checking the throttle plates. It's the easiest place to start troubleshooting the problem. Shine a light down the carb and see if the plates are closed. Then run the linkage open fully and let it close. Check that the linkage is allowing the plates to fully close and that there is not some binding or other interference keeping the plates partially open.
Lo-Fi Version | Time is now: 21st May 2024 - 08:56 PM |
