Antenna, WTB |
Antenna, WTB |
Speedo |
Sep 27 2021, 03:07 PM
Senior Member Group: Members Posts: 529 Joined: 7-November 06 From: Boulder Member No.: 7,170 Region Association: Rocky Mountains |
Sep 27 2021, 03:36 PM
914-6 GT in waiting Group: Members Posts: 19,219 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
I have a new Hirschman chrome antenna - HIT AUTO 2040 $40 + ship.
DucRS |
Sep 27 2021, 06:59 PM
Member Group: Members Posts: 105 Joined: 29-May 19 From: Riverbank CA Member No.: 23,173 Region Association: Central California |
If there’s a second one laying around, I’ll take it (IMG:style_emoticons/default/biggrin.gif)
Hoppie944s2 |
Sep 27 2021, 07:55 PM
Porschenut Group: Members Posts: 64 Joined: 7-July 13 From: New Jersey Member No.: 16,098 Region Association: North East States |
Ditto, if no one takes it , I will take it
Speedo |
Sep 30 2021, 11:19 AM
Does this look correct? Charles at Woodies claims this is correct...
https://www.ebay.com/itm/363469999223?mkevt...%2Cchnl%3Dmkcid |
914Sixer |
Sep 30 2021, 11:55 AM
914 Guru Group: Members Posts: 8,863 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Woodies are correct, HOWEVER most antennas were dealer installed. MEASURE diameter of your hole. Store has 2 different versions for the holes. You may find cable lead is too short and will require an extension.
I personally went with the more expensive Beru because it is stainless steel and has a replaceable cable lead. A200 is the model. This will ONLY work with SMALL HOLE. Attached image(s) |
Speedo |
Sep 30 2021, 04:34 PM
Fender hole is right at 7/8ths.
Speedo |
Sep 30 2021, 04:39 PM
Speedo |
Oct 19 2021, 04:19 PM
Still looking for an original antenna that fits a 7/8ths hole.
914e |
Oct 19 2021, 10:10 PM
Member Group: Members Posts: 496 Joined: 21-February 20 From: Arizona Member No.: 23,951 Region Association: Southwest Region |
I need a replacement antenna parts (or an entire antenna) for my 6. Let me know what you have that would be correct. The parts I need are on the base...so if you have some base parts as extras, let me know. Pics of what I have... Where was the hole drilled? That looks more like a Super Beetle antenna. |
Speedo |
Oct 24 2021, 05:46 PM
So I figured out what happened...and I still need some antenna parts. the area where the antenna attached was rotted and replaced. The replacement steel had an antenna hole but it was up higher on the fender and the mounting surface was more flat. Here is what I have...again, I need an antenna or parts to make mine work. Basically I need the plastic half sphere plastic and chrome cover.
Speedo |
Oct 24 2021, 05:55 PM
So I basically need the two items in the left of the picture for mounting on a flat surface vs the side of a hill...the plastic and the chrome cover. Or just the hole damn antenna if you have one. (IMG:style_emoticons/default/huh.gif) |
PCA7GGR |
Oct 24 2021, 07:58 PM
Member Group: Members Posts: 251 Joined: 3-October 03 From: Dublin, CA Member No.: 1,219 |
Lo-Fi Version | Time is now: 18th April 2024 - 06:56 PM |
