Headlight keeps cycling up and down, Thought I would pass it by everyone |
mmichalik |
Oct 4 2021, 01:34 PM
MikeM Group: Members Posts: 697 Joined: 27-January 16 From: Valley Center, CA Member No.: 19,600 Region Association: Southern California |
I'm currently having an issue with my 75. We have everything wired up after 10 years + of sitting.
When we turn on the headlights, the driver side headlight just cycles up and down continuously. I'm thinking that the wiper contact is just very dirty and that it will eventually wear through and begin to make contact again. Is that a safe assumption? If not, is there something that may be serviceable that I can clean to make the motor function as intended? Passenger side works as expected. Mike |
wes |
Oct 4 2021, 01:41 PM
wes Group: Members Posts: 1,588 Joined: 8-December 07 From: Ukiah Ca Member No.: 8,436 Region Association: Northern California |
Likely the relay, 914rubber has them!
mmichalik |
Oct 4 2021, 01:46 PM
iankarr |
Oct 4 2021, 02:15 PM
The wrencher formerly known as Cuddy_K Group: Members Posts: 2,473 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region |
Yep. Mine did that. New relay was the trick.
Lo-Fi Version | Time is now: 13th May 2024 - 07:13 AM |
