Calipers, Caliper kits, Caliper parts |
PatMc |
Oct 5 2021, 08:20 PM
Member Group: Members Posts: 120 Joined: 27-June 21 From: Long Beach Member No.: 25,669 Region Association: None |
We are Automotive Brake Solutions out of Long Beach CA.
We have quite a few 914 calipers in stock, so I thought I'd post them here. We typically stock both early and late fronts and rears, as well as the most complete rear rebuild kit available, NEW outer adjuster caps, New inner adjuster plugs w/ over sized hex, pads, and pad hardware. We also have new replacement rear pistons in stock. All of our calipers are refurbished in house, with the exception of the plating. We do not offer bare iron calipers or zinc plated calipers. All of our caliper bodies are cadmium plated. Cad plating offers roughly 6X the corrosion protection of zinc and has considerably better "throw" to fully protect the interior surfaces of the castings...so we'll do Cad as long as we can...with environmental issues, Cad plating is not going to be possible for any reasonable amount of money soon in CA. All pistons are ultrasonically cleaned, put through a 2 stage rotary polishing process, sealing surface masked and then they get media blasted and finished with 2 coats of high temp polyurethane. Hardware is stripped and black oxided Rears include new outer adjuster caps Fronts include new pad hardware. Give us a call if you're in need of 914 calipers, caliper parts, pads, etc... or even brake parts for your daily driver. We also stock 911, 944, and some BMW and Mercedes calipers. Front calipers are $269/pair and rears start at $289/pair, which includes shipping (lower 48). We require a $200 core charge per front set and $280 core charge per rear set, which is refunded as soon as we receive your complete and rebuildable cores back. Due to the availability issues associated with parts for early Porsches, we ask that you give us a call with any questions or to place an order at 562-512-4966 Website is up, here is link to the 914 section: https://autobrakesolutions.com/collections/porsche-914 Here are a few pictures Attached thumbnail(s) |
Lo-Fi Version | Time is now: 22nd May 2024 - 02:14 AM |
