First of the Texas Twins, First Build |
Puebloswatcop |
Oct 6 2021, 05:31 PM
Senior Member Group: Members Posts: 1,389 Joined: 27-December 14 From: Mineola, Texas Member No.: 18,258 Region Association: Southwest Region |
(IMG:style_emoticons/default/piratenanner.gif) So I finally got the first of the two Texas Twins down from Colorado down here to Texas and cant wait to get started on the build. I first obtained this 914 as a parts car back in 2010. After getting it home, I realized it was actually in better shape than the one I already owned. The first one is a 1973, 2.0. This one was a 1974 1.8 in Ravenna Green. Unfortunately I never was able to make allot of time to play with the car, so it sat in my overcrowded garage in Colorado.
Since I retired and moved to Texas, the wife said I had better find something to do and stay out from under her feet, so last week I made the treck to Colorado and brought the first of 3 914s back. (the 3rd really is a parts chassis). The car was on a rolling frame so was easy to get onto the trailer, problem is it had to be lowered enough to fit inside a four foot cover to be added onto the trailer, so first we had to raise it high enough to get it off the rolling frame. Then it had to be carefully lowered to where the car was sitting on 4 X 4 blocks so it would be lower than 4 feet high and secured to the trailer. It came in at around 3'8" when done. Then the shipping crate was built over and around the car. The trip was long and went well till I got about 10 miles from home and disaster struck. A catastrphic loss of one tire on the trailer. Thanks to a good samaritan who flagged me down, because I never heard or felt a thing. Also a testament to Top Hat Trailer Company, the trailer was slightly damaged but did not roll, in fact it rode so smooth that I never new the tire had gone away. Of course...no spare for the trailer, so I limped the last 10 miles at 15 miles per hour. So 16 hours of driving and now one of my babies is here in Texas and the work shall begin. |
oldie914 |
Oct 16 2021, 05:17 AM
Member Group: Members Posts: 102 Joined: 2-May 10 From: Germany Member No.: 11,680 Region Association: None |
You might consider using generic bearings instead of Porsche as you continue. Not all bearings are generic but they are a lot cheaper. Porsche often assigned 900xxxx part numbers to generic parts.
In your case, the upper bearing has 6003 engraved which is an identification of the bearing type and size under the metric bearing system. FAG has a catalog online that lets you decipher the numbers. I checked the US internet and saw the Porsche bearing cost $17. An FAG 6003 cost $6. Over here in Germany, Porsche costs Euro 27 ($30) and an FAG 6003 Euro 3. The other bearing appears to be Porsche specific but I imagine it is a standard metric bearing in a plastic case. Last point is only use name brand bearings. There are many poor quality Chinese made bearings offered. |
Puebloswatcop |
Oct 16 2021, 06:32 AM
You might consider using generic bearings instead of Porsche as you continue. Not all bearings are generic but they are a lot cheaper. Porsche often assigned 900xxxx part numbers to generic parts. In your case, the upper bearing has 6003 engraved which is an identification of the bearing type and size under the metric bearing system. FAG has a catalog online that lets you decipher the numbers. I checked the US internet and saw the Porsche bearing cost $17. An FAG 6003 cost $6. Over here in Germany, Porsche costs Euro 27 ($30) and an FAG 6003 Euro 3. The other bearing appears to be Porsche specific but I imagine it is a standard metric bearing in a plastic case. Last point is only use name brand bearings. There are many poor quality Chinese made bearings offered. You're right. The FAG 6003 was fairly easy to source and is the way I went, The other bearing on the other hand, seemed that no matter where I went they could not find a cross reference for. It was quite difficult, so I went with the OEM bearing. Unfortunately there aren't too many places out here in east Texas to source this stuff unless I want to make the 2 hour drive to Dallas...lol |
Lo-Fi Version | Time is now: 14th May 2024 - 11:35 PM |
