First of the Texas Twins, First Build |
Puebloswatcop |
Oct 6 2021, 05:31 PM
Senior Member Group: Members Posts: 1,389 Joined: 27-December 14 From: Mineola, Texas Member No.: 18,258 Region Association: Southwest Region |
(IMG:style_emoticons/default/piratenanner.gif) So I finally got the first of the two Texas Twins down from Colorado down here to Texas and cant wait to get started on the build. I first obtained this 914 as a parts car back in 2010. After getting it home, I realized it was actually in better shape than the one I already owned. The first one is a 1973, 2.0. This one was a 1974 1.8 in Ravenna Green. Unfortunately I never was able to make allot of time to play with the car, so it sat in my overcrowded garage in Colorado.
Since I retired and moved to Texas, the wife said I had better find something to do and stay out from under her feet, so last week I made the treck to Colorado and brought the first of 3 914s back. (the 3rd really is a parts chassis). The car was on a rolling frame so was easy to get onto the trailer, problem is it had to be lowered enough to fit inside a four foot cover to be added onto the trailer, so first we had to raise it high enough to get it off the rolling frame. Then it had to be carefully lowered to where the car was sitting on 4 X 4 blocks so it would be lower than 4 feet high and secured to the trailer. It came in at around 3'8" when done. Then the shipping crate was built over and around the car. The trip was long and went well till I got about 10 miles from home and disaster struck. A catastrphic loss of one tire on the trailer. Thanks to a good samaritan who flagged me down, because I never heard or felt a thing. Also a testament to Top Hat Trailer Company, the trailer was slightly damaged but did not roll, in fact it rode so smooth that I never new the tire had gone away. Of course...no spare for the trailer, so I limped the last 10 miles at 15 miles per hour. So 16 hours of driving and now one of my babies is here in Texas and the work shall begin. |
Puebloswatcop |
Oct 20 2021, 04:50 PM
Okay, so after spending over an hour this morning trying to figure out why the welder would feed consistently, turns out the label on the wire spool started peeling away and was building up like a snowball behind the spool. Cheap and easy fix.
So I cut out the support structure for the mirror on the drivers door. As it turns out there are actually 3 layers to this part of the door. 1) the outer skin, 2) the sheet metal support, 3) the nut plate that the mirror screws into. In my case all 3 had been destroyed. So I started by making the sheet metal support. I tried using the pieces I cut out to make the holes for the new piece and that was a mistake. They were off by about a 16th of an inch. So I grabbed an old broken mirror and made a new one using the proper measurements... Then measured to make a new screw/nut support plate. After drilling the holes, I tapped them to fit the mounting screws for the mirror.... Then welded the screw / nut support to the sheet metal support. Then welded the sheetmetal support back into the door .... Then double checked the allignment by attaching the mirror to the support. I am please with the allignment in the end. Tomorrow I will weld the outer skin back onto the door. |
Lo-Fi Version | Time is now: 14th May 2024 - 08:53 PM |
